how much hp will the honda ignition take before it starts to break up?
Re: (vaporboy12)
When I got up around 20 lbs of boost it started missing. I tried the MSD cap/CDI/coil combo, which worked if I kept the plugs gapped close, like .020 . Now I have COP, no misses at 20+ PSI with a .040 gap.
Re: (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels »</TD></TR><TR><TD CLASS="quote">When I got up around 20 lbs of boost it started missing. I tried the MSD cap/CDI/coil combo, which worked if I kept the plugs gapped close, like .020 . Now I have COP, no misses at 20+ PSI with a .040 gap.</TD></TR></TABLE>
COP?
COP?
Re: (GodFather of Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GodFather of Boost »</TD></TR><TR><TD CLASS="quote">I have made 600+ on stock ignition including wires. Plugs gapped at .25</TD></TR></TABLE>
is that .25mm? or .025"?
How do you know if the stock coil is not enough already? do you get detonations? or it just misfires? Thanks!!!
Re: (FOrSfEd)
Just misfires, and I didn't even notice them, but they showed up on the dyno. There's some other less quantifiable stuff too, like the possibility of adding more fuel earlier with a stronger spark and a bigger gap, but I'd have to set up a controlled test for that and dyno tuning time ain't cheap.
Re: (RRL)
sorry i meant .025 and yes you will start noticing misfires on the dyno graph before you will feel them. That will be the point at which you will actually make power with an aftermarket ignition system.
Re: how much hp will the honda ignition take before it starts to break up? (vaporboy12)
Prelude ignition systems are a bit finickier than the B series. Typically around 330-400 they may start to break up a little bit.
Prelude's also have a lower msbc than the B series do which also does not help.
nowidriveacivic
Engine Management and Tuning
17
08-05-2010 09:29 AM
