Oil return line question
Old Oct 13, 2004 | 04:15 PM
d15b7racer's Avatar
Default Oil return line question
i have a greddy turbo kit and wanted to replace my oil return line. Its that crappy rubber one. I tried calling a couple auto parts store for oil lines but most say they dont have anything larger than 1/2". Greddy told me that the ID of the line is 19mm or 3/4". Is heater hose or any other hose able to carry oil or is there a real big difference between those hoses?
Old Oct 13, 2004 | 04:20 PM
EJ1 wilcox's Avatar
Default Re: Oil return line question (d15b7racer)
Make sure you get hose that can withstand a lot of heat and pressure! You don't want it melting or failing on you!
Better yet, just pick up a stainless steel drain kit from fast-turbo.com
Old Oct 13, 2004 | 05:12 PM
Bailhatch's Avatar
Default Re: Oil return line question (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you get hose that can withstand a lot of heat and pressure!
There is no pressure at all.
You need to ask for an oil rated hose. NAPA carries a red universal hose that is oil rated.
The blue silicon EGR repair hose that many auto parts stores carry in 1/2" 5/8" and 3/4" works very well and happens to be the exact same brand and hose that some turbo companies sell as an oil return. 5/8" is only $7 a foot at my local Carquest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Better yet, just pick up a stainless steel drain kit from fast-turbo.com </TD></TR></TABLE>
Stans return line kits are definitely one of the best options but cost several times more. Ask him about the push lock hose which is cheaper, easier to assemble and works well.
SOHC_2_DOHC
Oct 30, 2007 06:06 AM
vietelement
Jul 8, 2007 02:17 PM
bayoufrogg
Aug 26, 2005 01:04 PM
metal-x
Mar 10, 2003 04:36 AM
Jockobo
Jun 15, 2002 07:41 PM
