Pic/Diagram request. Coolant lines T to the turbo
My turbo is water and oil cooled, im not sure how to connect the hose from the turbo to the coolant line, does it matter where i "T" it??
Re: Pic/Diagram request. Coolant lines T to the turbo (sPaRk'iT)
Remove the IACV coolant line and use the nipple from the main water pipe to feed the turbo. This will circumvent all of the throttle body and IACV coolant lines.
If you opt to not circumvent those lines, then you can tee off of the PCV purge heater line.
Tap a NPT to 1/4" or 5/16" barbed fitting into the upper radiator hose housing.
I'd be able to help you more if you told me if it was an OBD-1 or OBD-2 motor.
mine is a sohc and I did as (in vtec) said in a way.
-run your turbo feed line from the return of the iacv to the turbo.
-run it from the turbo to the water pipe on the back of the block.
-Ill see if I can get some pics to work!
Re: Pic/Diagram request. Coolant lines T to the turbo (sleeping GIANT)
find the circled nipple on your water pump connecting pipe. take off the hose, and run your feed from the end of the hose on the intake mani. and route ur return line back to the nipple.
