Whats the Powerfullest three b16a turbo engine?
Re: Whats the Powerfullest three b16a turbo engine? (OTT)
i'd go US spec b16a2....lower comp I believe than the JDM ones and also newer (w/ less miles). Also, B16b cams are very agressive and ignition timing will be an issue as well as the higher compression (2nd highest on all b series?)
its <U>most</U> powerfull anyway I think it may be these..
https://honda-tech.com/zerothread?id=712430
608whp
https://honda-tech.com/zerothread?id=704660
616whp
but thats just on this site, I personally know of one 600hp b16 here, and I am sure there are many across the country. and this is without Nitrous
EDIT- sorry the first is a b16b, you wanted b16a
608whp
616whp
I cant wait to see what you lay down.
Youve got impressive numbers already, having 600ponies under your right foot is lots of fun I expect.
did you do anything to the transmission to strenghen it or changeout the final drive? and what driveshafts are you using?
Cheers
Cheers
talk about lag.. that b16b doesnt even hit over 100whp until almost 6,000 rpm.. with that kind of spool there is no way its streetable. I'll be willing to bet you could step on it at 2,000 rpm in 4th and when it hits full spool at almost 7,000 rpm the tires break loose
well you do size your turbo to your application dont you. What you say will be true but its still drivable on the street, just you have to be high up in the rev range to spool.
Re: (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">nothing to do to the tranny except clutch,pressure plate and lsd. the gears wont break if thats what you mean.</TD></TR></TABLE>
600ponies with equally impressive torque and the stock gears should hold??
Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">Hey Boostage, how much money do you have tied up in that motor? Just curious because that thing is INSANE!!! </TD></TR></TABLE>
No man, you mean Boostfed. he is the one with the 6 million hp b16. not me.
Re: (OTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTT »</TD></TR><TR><TD CLASS="quote">I cant wait to see what you lay down.
Cheers</TD></TR></TABLE>
Ever driven a 600 WHP FWD honda? I'll give you an idea of what it's like on the street.
WOT --- waiting ---- waiting - SPOOL- BRAAAAAAAAAAAAAAAAAAAAAAAAAAP as the tires break lose, shift
waiting ---- waiting - SPOOL - BRAAAAAAAAAAAAAAAAAAAP as the tires break lose, shift
oh, I just shifted into fourth, but since I was spinning so ungodly hard I'm actually only going 50 MPH, now I'm going to bog down big time and have to downshift
It sounds great on paper, but 600 WHP on the street I didn't find all that fun. Something in the range of 400-450 WHP is enough so that you can beat 99.99% of what else is driving with 4 wheels out there, but not so powerful that it smotes the tires from any speed.
Re: (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip »</TD></TR><TR><TD CLASS="quote">
It sounds great on paper, but 600 WHP on the street I didn't find all that fun. Something in the range of 400-450 WHP is enough so that you can beat 99.99% of what else is driving with 4 wheels out there, but not so powerful that it smotes the tires from any speed.</TD></TR></TABLE>
yeah but 400-450 wont beat 700hp v8's and supras. I realise not everyone lives in an aera where there are lots of those, but if you live Miami/ft lauderale. u know what I mean.. well in a hatch it can be done but not a coupe I dont think.
Re: (Boostage)
yeah but 400-450 wont beat 700hp v8's and supras. I realise not everyone lives in an aera where there are lots of those, but if you live Miami/ft lauderale. u know what I mean.. well in a hatch it can be done but not a coupe I dont think.</TD></TR></TABLE>
700 HP = approx. 600 RWHP through a stick. A 600 RWHP supra is going to be running low 130 traps, so is an LS1 camaro. A 600 RWHP fox body mustang is going to be going mid-high 130's, 450 WHP will take care of mid 130 traps in a hatch, so why not? 600 WHP should be good for well over 140 MPH traps, even in a full interior coupe.
Re: (Chip)
700 HP = approx. 600 RWHP through a stick. A 600 RWHP supra is going to be running low 130 traps, so is an LS1 camaro. A 600 RWHP fox body mustang is going to be going mid-high 130's, 450 WHP will take care of mid 130 traps in a hatch, so why not? 600 WHP should be good for well over 140 MPH traps, even in a full interior coupe.</TD></TR></TABLE>
yeah, once u get to teh 130 trapping area, other cars find it very diffuclt to beat or keep up with you.
mahleeh
12-23-2007 11:28 AM
