AFC-HACK <--How many of you are running it?
Old Oct 12, 2004 | 06:36 AM
al3e's Avatar
Default AFC-HACK <--How many of you are running it?
...How many of you people here like the idea?...
(not like its going to change my opnion right now)
Im just wondering.
and or using the SFC-VTEC controller?
Old Oct 12, 2004 | 06:40 AM
Joseph Davis's Avatar
Default Re: AFC-HACK <--How many of you are running it? (al3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by al3e &raquo;</TD></TR><TR><TD CLASS="quote">...How many of you people here like the idea?...
(not like its going to change my opnion right now)</TD></TR></TABLE>
Your opinion will change in direct proportion to your attention span and intellect: https://honda-tech.com/zerothread?id=841443
Old Oct 12, 2004 | 12:55 PM
mchuang's Avatar
you should search it there is tons on it
Old Oct 12, 2004 | 01:08 PM
bbarbulo's Avatar
I was gonna run it, cuz it works fine, but I got Hondata instead and sold my SAFC to some DSM'er
Old Oct 12, 2004 | 01:12 PM
thermal's Avatar
me... on my civic. numbers on my sig. go Hondata instead....
Old Oct 12, 2004 | 01:47 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
I think people just like including the word 'hack' in their mod list.
Old Oct 12, 2004 | 01:52 PM
Default Re: (bbarbulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo &raquo;</TD></TR><TR><TD CLASS="quote">I was gonna run it, cuz it works fine</TD></TR></TABLE>
Attention span! Intellect! Acquire them!
Old Oct 12, 2004 | 02:34 PM
safe driver's Avatar
i used to run it. it ran fine. but i had a msd digital6+ set at 5° retard. im running an AEM EMS now because i want to pretend to be a tooner.
Old Oct 12, 2004 | 03:03 PM
gotboost95's Avatar
I ran the hack car was pretty fast. Then I blew my motor with it
at 8psi Now I'm on uberdata and love it.
Old Oct 12, 2004 | 03:38 PM
ILLICON3000's Avatar
works great for me
Old Oct 12, 2004 | 03:46 PM
ComputerJLT's Avatar
Default Re: (ILLICON3000)
uberdata bitches
its cheaper than the hack and just as tuneable as hondata
Old Oct 12, 2004 | 04:02 PM
twkdCD595's Avatar
Default Re: (ComputerJLT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComputerJLT &raquo;</TD></TR><TR><TD CLASS="quote">uberdata bitches
its cheaper than the hack and just as tuneable as hondata</TD></TR></TABLE>
actually the hack was cheaper for me and for others that have to change ecu's to make the uberdata work. so for now I am running the hack but I despritely want to switch to a p28/ uberdata. the problem is the p28's are pricey and everyone knows they are worth more now (100ish+).
I have been hanging on for some P0A or p13 support, but it seens the help will never come... I try to read up as much as I can on pgmfi and uberdata forum.
anyways I have alot of retard in the timing, and dont daily drive my car... when I do I never roll into throttle with it loaded up in gear@ low rpm (so I dont hang in the hella advanced area).
überdata
Old Oct 12, 2004 | 04:10 PM
Default Re: (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">
überdata </TD></TR></TABLE>
does whatever motor yours have have vtec? if it doesn't a cheap p06 would work; and if it does a p06 can be converted. i have a p06 and have been running it and will mod it to a p28 to control vtec when i get my Z6 head and all the parts for my budget d16z6 buildup in and machine work done.
Old Oct 12, 2004 | 06:29 PM
twkdCD595's Avatar
yeah I am an sohc vtec.
Old Oct 12, 2004 | 06:45 PM
thermal's Avatar
OBD2 + AFC hack = CEL code 13 (barometric reading error)
96y7turbo's Avatar
i got it.. running 7psi with 4 deg retard at the distributor.. . it works.. thats about it.. i was doing some reading including jdavis' post and they are right.. to much timing advance is not good.. im gonna up the boost this weekend and hit the dyno so i can go racing on sunday. hopefully it wont blow.. next year im doing a obd2-1 conversion and run uberdata for sure...
Old Oct 12, 2004 | 06:54 PM
twkdCD595's Avatar
Default Re: (96y7turbo)
on the thread by j davis he says the timing advance makes it suck but more boost is better pretty much, you will have more advance at 7 psi than 10 psi basically. (I sure he will correct me accordingly)
Modified by twkdCD595 at 10:09 PM 10/12/2004
Old Oct 12, 2004 | 07:01 PM
USDM 4G VTEC's Avatar
i have it now for 5 mths
5k miles
9 psi daily beaten
makes 180whp and 163wtq
idles great hot or cold, and runs great
trying to get turboeit working for me tho...
Old Oct 12, 2004 | 07:19 PM
jl2teg's Avatar
Default Re: (USDM 4G VTEC)
word on the turbo edit
Old Oct 12, 2004 | 07:55 PM
japrex's Avatar
i will be running the hack setup with a msd 6al BTM on my crx with boosted b16. it should do the job for a while until i afford something better. its cheap and effective.
Old Oct 12, 2004 | 08:47 PM
BME1986's Avatar
Default Re: (japrex)
I am running the Hack but only until I get my 5sp swap and I am switching to uberdata.
Old Oct 12, 2004 | 08:57 PM
SOHC_MShue's Avatar
Default Re: (thermal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermal &raquo;</TD></TR><TR><TD CLASS="quote">me... on my civic. numbers on my sig. go Hondata instead....</TD></TR></TABLE>
what is wrong with your civic? Its making terrible power at 10psi, but decent torque. Is your torque curve just falling off in high rpms?
Old Oct 12, 2004 | 11:12 PM
al3e's Avatar
dang... thanks alot guys...
O RLY
Honda Civic (2006 - 2015)
15
Aug 21, 2008 09:57 PM
HiPhOpHeADs
May 4, 2005 08:27 PM
tegedrex
Jun 3, 2004 08:02 AM
breakneckvtec
Jan 20, 2004 06:48 AM
BoostedH23a1
Oct 20, 2003 10:18 PM
