Golden Eagle or Race Engineering Block Guard?
Old Oct 13, 2004 | 12:53 AM
Project99EK's Avatar
Default Golden Eagle or Race Engineering Block Guard?
I hear alot of good things about GE's but im curious about Race eng. i have aheard a few good comments about it. Is it just drop in easy like the GE's?
*EDIT*
Well after a alot of time with a dremel and some 1500 grit sand paper success? =p.
*PS Imagestation is gay*
Modified by Project99EK at 6:56 PM 10/19/2004
Old Oct 13, 2004 | 08:41 AM
Default Re: Golden Eagle or Race Engineering Block Guard? (Project99EK)
^Bump^
Old Oct 13, 2004 | 09:04 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Yea its supposed to be a drop in...but then again all of them are i think. But they rarely just drop in. Most of the time the need a little persuasion with a file and a hammer. I dont use them because im afraid ill warp a cylinder or something....but ive put them in for people before. Ive seen both of them and i honestly dont see a big difference between the two.
Whats this going on...and whats the rest of the setup?
Old Oct 13, 2004 | 09:05 AM
rextec's Avatar
neither. i would go with block posting if you arent going to sleeve your block.
Old Oct 13, 2004 | 09:18 AM
4-banging's Avatar
Default Re: (rextec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">neither. i would go with block posting if you arent going to sleeve your block.</TD></TR></TABLE>
please elaborate
Old Oct 13, 2004 | 09:25 AM
ekb18c's Avatar
Just go with sleeves in the long run your wallet to thank you.
Old Oct 13, 2004 | 10:02 AM
kine462's Avatar
Default Re: (4-banging)
block posting( i'm not for it) is when you bore holes on the outer part of your block into the water jacket and tap the holes to make threads. you buy threaded plugs made out the same material as your engine block and screw the posts or plugs into the holes you had drilled to reinforce the outsides of your sleeves. home made turbo has a write up on their main page. http://www.homemadeturbo.com
Old Oct 13, 2004 | 10:22 AM
4-banging's Avatar
Default Re: (kine462)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kine462 &raquo;</TD></TR><TR><TD CLASS="quote">block posting( i'm not for it) is when you bore holes on the outer part of your block into the water jacket and tap the holes to make threads. you buy threaded plugs made out the same material as your engine block and screw the posts or plugs into the holes you had drilled to reinforce the outsides of your sleeves. home made turbo has a write up on their main page. http://www.homemadeturbo.com </TD></TR></TABLE>
that seems to be a really bad idea. thanks, I'll do some more research on it
Old Oct 13, 2004 | 11:19 AM
Muckman's Avatar
Moderator in Chief
Not nessecarily bad. Just alot of room for error
Old Oct 13, 2004 | 11:29 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (Muckman)
a shitload room for error .
honestly i dont think block guards have been prooven to be a usefull part....i think better tuning will save your sleeves not a block guard
Old Oct 13, 2004 | 03:08 PM
Default Re: Golden Eagle or Race Engineering Block Guard? (sCeRaXn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sCeRaXn &raquo;</TD></TR><TR><TD CLASS="quote">
Whats this going on...and whats the rest of the setup?</TD></TR></TABLE>
Its going on a Gsr with a t3/t4 turbo
Old Oct 13, 2004 | 03:42 PM
alpha's Avatar
If you are going todo a block guard spend the extra money. Have a machine shop weld the block guard in. Is this going to be a stock piston/rod setup or aftermarket forged piston/rod setup?
Old Oct 13, 2004 | 05:29 PM
Default Re: Golden Eagle or Race Engineering Block Guard? (0x64)
Old Oct 14, 2004 | 09:38 AM
rextec's Avatar
Default Re: (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">a shitload room for error .
honestly i dont think block guards have been prooven to be a usefull part....i think better tuning will save your sleeves not a block guard</TD></TR></TABLE>
im with this guy. ive seen both b and d series make little over 400whp on stock sleeves.
Old Oct 14, 2004 | 10:06 AM
DA9-T's Avatar
Make sure to hone after you install the block guard. I am going the same route, block guard but with forged pistons and rods. I don't invision myself running anything more than 15 psi or 300-350 whp, so I wouldn't be seeing any of the "benefits" of sleeving my block. It all comes down to what your goals are.
O yeah, back you your question, I am going with the Race engineering blockguard. I guess its just personal preference but i like their style of bg's better than ge's.
Old Oct 14, 2004 | 10:45 AM
Sonny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-banging &raquo;</TD></TR><TR><TD CLASS="quote">
that seems to be a really bad idea. thanks, I'll do some more research on it </TD></TR></TABLE>
It's been working great for me. Just be careful and take your time.
http://www.muller.net/sonny/crx/engine/posted.html
I've got about 5000 miles on the block now. No probs.
Sonny
Old Oct 19, 2004 | 09:57 AM
ttt
Old Oct 19, 2004 | 10:56 AM
eastbay92cx's Avatar
Larry of endyn (not that i know him personally) does this block posting, and I'm not going to call any of his engine building practices bad.
See: his daily driven supercharged d16 putting down ~500(?) hp.
racehard
Feb 19, 2009 03:24 PM
TypRice
Feb 22, 2006 06:05 PM
allmotorb20vtec
May 24, 2005 10:52 PM
jDMJeRk
Jan 28, 2004 10:41 PM
