exhaust gasket question
Old Oct 13, 2004 | 07:47 AM
PLRacer's Avatar
Default exhaust gasket question
does anyone know where i can get an exhaust gasket for a Garrett T3/TO4E?
i bought one from atpturbo but its way too big...i tried looking around in other places but i can't find one.
and yes the gasket is necessary....there is a noticable gap between the turbo and downpipe. plus im only using 3 out of the 4 bolts so i really want to use a gasket to make sure there is no leaks.
Old Oct 13, 2004 | 06:29 PM
PLRacer's Avatar
Default Re: exhaust gasket question (PLRacer)
someone has to know something...
Old Oct 13, 2004 | 07:15 PM
NVturbo's Avatar
O.G. triple O.G.
Try giving Andre @ Turbo Exchange a call. I am pretty sure he will have what you are looking for. The shop's number is 704-721-6661 (Concord, North Carolina).
Old Oct 13, 2004 | 11:10 PM
PrettyLude's Avatar
http://www.roadraceengineering...s.htm
Old Oct 14, 2004 | 10:49 AM
PLRacer's Avatar
Default Re: (PrettyLude)
does anyone know if the 7cm Turbine Housing Gasket is what i need? http://roadraceengineering.com...s.htm
7cm is about 2.75in, bu the outlet is closer to 2.5in, i just dont want to waste more time and money?
Old Oct 14, 2004 | 12:32 PM
Evanmb44's Avatar
first of all, you may want to look into getting the downpipe closer to the turbo..i dont know how far away it is b/c no pics...downpipe should be able to move close enough to mate w/ the flange onthe turbo, if you can get that far use some high temp silicone gasket maker...its the orange stuff...thats what i use and it holds great...but there shouldnt be a large gap between the two
Old Oct 14, 2004 | 01:06 PM
PLRacer's Avatar
Default Re: exhaust gasket question (Evanmb44)
i get the bolts as tight as i can and when i look fromunder the car i can actually see light passing through
do u think the silicone would be enough?
Old Oct 15, 2004 | 06:12 AM
PLRacer's Avatar
soemone help me out please.......i need to get this done ASAP
Old Oct 15, 2004 | 08:10 AM
Evanmb44's Avatar
ok...first of all, disconnect the downpipe from the cat/test pipe or whatever you are using...then connect it to the turbo and silicone it...if it is not connected at the cat then you should be able to get it mate with the turbo...then you have to connect the downpipe to the cat...you may have to modify it or put a piece of flex pipe near the end of your downpipe in order for it to connect...that is the best way to go about that
Old Oct 18, 2004 | 07:11 AM
PLRacer's Avatar
any other input before i try silicone?
swappedcx
Jul 30, 2006 03:00 PM
dester223
Dec 16, 2005 08:26 PM
SexyH22
Oct 19, 2005 09:51 AM
DaX
Apr 4, 2005 08:34 AM
swlabhot
Jun 12, 2003 07:35 AM
