9:9:1 comp D and ihi rhb5?
Old Oct 10, 2004 | 03:56 PM
AF-b16a1's Avatar
Default 9:9:1 comp D and ihi rhb5?
i was wondering if this setup would be ok to run with (y7/y8 minime with 7-9 psi of boost)...i saw another member with a 10:6 compression (d15/y8 head) runnin 9 psi...and seems like he is doing well with his setup...is 9:9:1 to much? or ok?...i plan to use uberdata..have the p28 w/ basemap already...and would i be ok to run on a basemap for now? just tryin to do some stuff while my vitara setup is being built...any suggestions would help...
Old Oct 10, 2004 | 03:58 PM
Devine's Avatar
Default Re: 9:9:1 comp D and ihi rhb5? (AF-b16a1)
I wouldnt boost on the basemap but with your uberdata tuned you should have no worries.
Old Oct 10, 2004 | 04:10 PM
AF-b16a1's Avatar
so meaning 0 boost on a basemap?
Old Oct 10, 2004 | 04:45 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
As long as you use a good intercooler and well tuned engine management you should be fine. No, I wouldn't boost AT ALL on a base map.
Old Oct 10, 2004 | 04:46 PM
nonvtecD's Avatar
Basemaps purpose is to be safe, make it rich, pull timing, it won't make as much power as possible, but it wont blow.
Old Oct 10, 2004 | 04:59 PM
AF-b16a1's Avatar
oh ok...thanks for the info
Old Oct 10, 2004 | 06:17 PM
93turbo16's Avatar
You can boost on a basemap. It will just won't be as good as a tuned map. You just have to MAKE SURE you have enough timing out and fuel in.
Ahknodd
Feb 22, 2009 05:57 PM
DrivinVtec
Jan 25, 2007 06:33 PM
BauleyCivic
Jan 6, 2006 10:36 AM
f1 vtec
Nov 1, 2004 09:38 PM
C ronic
Dec 15, 2002 03:01 PM
