Twin Turbo?
Old Oct 14, 2004 | 06:33 AM
BigPlansNoMoney's Avatar
Default Twin Turbo?
Is there like a rule of thumb that you must have ateast three cylinders feeding a turbo, becaause I haven't seen TT on any other vehicles less than 6 cyls (Skylines, Supras, Big Block Chevys) has anyone done it successfully in a Honda 4 banger?
Old Oct 14, 2004 | 06:35 AM
DaveF's Avatar
Default Re: Twin Turbo? (Justin_Bradley)
never, noone has ever done it
SEARCH PAL
Old Oct 14, 2004 | 06:37 AM
underpressure02's Avatar
no drt had twin turbo, abaz on here did a twin turbo setup. I have seen a few at car shows.
Old Oct 14, 2004 | 06:40 AM
DaveF's Avatar
Default Re: Twin Turbo? (underpressure02)
shut the hell up kid, you nver seen one before.
Old Oct 14, 2004 | 07:18 AM
HybridKOOP's Avatar
Default Re: Twin Turbo? (Dturbocivic)
I'm working on a triple-turbo setup on my Festiva 3-cylinder.
Old Oct 14, 2004 | 11:18 AM
So a four cylinder can handle all of that boost?
Old Oct 14, 2004 | 11:26 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin_Bradley &raquo;</TD></TR><TR><TD CLASS="quote">So a four cylinder can handle all of that boost?</TD></TR></TABLE>
A motor can not distinguish if boost pressure comes from one, two, or even 13214131515 turbos. Pressure is Pressure. Don't run more than your motor can handle and you'll be fine. Efficiency and spool times will vary greatly though.
K.I.S.S. 'Nuff said.
Old Oct 14, 2004 | 11:49 AM
Chip's Avatar
Default Re: Twin Turbo? (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
K.I.S.S. 'Nuff said. </TD></TR></TABLE>
Pressure is not pressure. Airflow is airflow. 12 psi from a T3/TO4E 50 trim is not 12 psi from a PT88.
Old Oct 14, 2004 | 11:53 AM
Finest's Avatar
Default Re: Twin Turbo? (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">
Pressure is not pressure. Airflow is airflow. 12 psi from a T3/TO4E 50 trim is not 12 psi from a PT88.</TD></TR></TABLE>
I think you misunderstood.
I was referring to his comment on "So a four cylinder can handle all of that boost?" in relation to twin turbos on a 4 banger. Pressure is pressure, in the sense that a motor does not care if that boost pressure came from one big honking turbo or 2 little ones.
Old Oct 14, 2004 | 11:57 AM
PrettyLude's Avatar
drt did have one, but it didn't last too long
Old Oct 14, 2004 | 11:59 AM
donkiman's Avatar
its been done before. theres a few archived posts on this site with twin turbo setups. the general feedback from it is that they are not as happy as they thought theyd be with it. It could be practicle for a fast track car but for street driving, you might as well invest in a different car unless of course you own a shop and can bend all the piping and fabricate **** yourself... then it could be a fun project.
Old Oct 14, 2004 | 12:03 PM
Curtisbeef's Avatar
Now you can all shutup it has been done
Old Oct 14, 2004 | 12:08 PM
Finest's Avatar
Default Re: (Curtisbeef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curtisbeef &raquo;</TD></TR><TR><TD CLASS="quote"> [img]Now you can all shutup it has been done</TD></TR></TABLE>
I don't think anyone was saying that it can't be done.
Old Oct 14, 2004 | 12:23 PM
Chip's Avatar
Ah, gotchya
Old Oct 14, 2004 | 12:35 PM
powerls's Avatar
doesn't the audi tt have 2 turbo's. i dunno
Old Oct 14, 2004 | 12:40 PM
el arbi's Avatar
Default Re: (powerls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerls &raquo;</TD></TR><TR><TD CLASS="quote">doesn't the audi tt have 2 turbo's. i dunno</TD></TR></TABLE>
No its a single turbo
Old Oct 14, 2004 | 01:27 PM
VisualAutoMotoring's Avatar
Its Bi-Turbo whatever that means...that's in the S4
Old Oct 14, 2004 | 01:58 PM
Boosted_92's Avatar
Default Re: (PRojectSi2)
bi-turbos like both male and female turbos
Old Oct 14, 2004 | 02:13 PM
DeadLock23's Avatar
the last geb rx-7 were twin turbo I think
they were only 1.3 lit. motors, ofcourse they were rotary.........
Old Oct 14, 2004 | 02:31 PM
genetsang's Avatar
hope Raf dont mind me posting this
that was his old setup... since then, hes back with the single turbo setup
Old Oct 14, 2004 | 07:36 PM
Finest's Avatar
Default Re: (Boosted_92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_92 &raquo;</TD></TR><TR><TD CLASS="quote">bi-turbos like both male and female turbos</TD></TR></TABLE>
Old Oct 14, 2004 | 07:42 PM
Ri5e's Avatar
Default Re: Twin Turbo? (genetsang)
There was a post like last week about this or something...I hate these kinda posts! LOCK!
Old Oct 14, 2004 | 08:47 PM
ChrisRicketts's Avatar
Default Re: Twin Turbo? (TurboSmart)
there would be no reason to do such a thing. why do you think that factory twin-turbo'd supras and rx7's are going to single turbo setups? Because single turbo is more efficient.....that's why. sure, it would make a neat little project to quadruple turbocharge a four-banger, but it will be more efficient and easier to put one.
"just because you can do it doesn't mean its to be done. hell, you could drive a car with your feet if you want to, but that doesn't make it a good phuckin' idea."-Chris Rock
Old Oct 14, 2004 | 09:02 PM
ProjectDarkBlack's Avatar
there are two reasons to do a twin turbo set up, one is on a v6 or v8 where the exhaust ports are on the opposite sides of the engine bay, making a single turbo impractical, or when there is a large turbo that takes a lot to spool it, using a low rpm low boost turbo with a large turbo helps generate low rpm power and helps spool the the larger turbo faster, best of both worlds (same concept as vtec) but now that there are bad *** ball bearing turbos that spool easily, and a single turbo set up on a honda already takes up the space of a small farm animal, it just isnt practical
there are cars with single turbos on V from the factory, and it just plain doesn`nt look right
Old Oct 14, 2004 | 09:14 PM
Milano98teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRojectSi2 &raquo;</TD></TR><TR><TD CLASS="quote">
Its Bi-Turbo whatever that means...that's in the S4</TD></TR></TABLE>
and the rs6
