Fuel Needed For 12psi?
Old Oct 12, 2004 | 06:20 AM
larryd's Avatar
Default Fuel Needed For 12psi?
What fuel mods would you suggest for a GS-R with JRSC running 12psi. Currently I am on stock injectors with a rising rate fuel pressure regulator and Walbro 255 pump. I'm experiencing detonation but only sometimes. What do you suggest?
Old Oct 12, 2004 | 06:21 AM
tgreaves's Avatar
Default Re: Fuel Needed For 12psi? (larryd)
Getting a fuel management system that you can tune along with some dsm 450's and youll be good..
Old Oct 12, 2004 | 06:41 AM
Joseph Davis's Avatar
Default Re: Fuel Needed For 12psi? (tgreaves)
What he said. 2 bar MAP sensor is crucial to read above 10.6 psig, JRSC need ignition maps redone to avoid pingies.
Old Oct 12, 2004 | 02:33 PM
larryd's Avatar
What fuel management system do you suggest? Keep in mind that I may eventually end up selling the JRSC to go turbo.
Old Oct 12, 2004 | 03:18 PM
spyderracing's Avatar
Default Re: (larryd)
Hondata
Uberdata
AEM EMS
Any one of those 3 are good, uberdata requires that you have a WB O2 and a laptop to tune it yourself though.
donkiman's Avatar
call around and check around to local shops and see what there best at tuning. if someone tunes uberdata go with that. other wise hondata tuners are pretty common.
mr. Grind
Aug 12, 2004 07:00 PM
00bluesi
Feb 25, 2004 11:55 AM
MachAF
Mar 9, 2003 04:53 PM
grand600
Sep 27, 2001 09:58 PM
