IHI RHB5
Old Oct 11, 2004 | 09:28 AM
Pete_SI's Avatar
Default IHI RHB5
I just bought a IHI RHB5 and I want to know what kind of manifold would fit on it. Also there's something that looks like a solenoid with 2 wires comming out of it and 2 line that would look like oil or coolant.
Old Oct 11, 2004 | 10:43 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: IHI RHB5 (Pete_SI)
There are a few different RHB5s. Which one do you have? Got pics? Numbers? Know what it came from?
Old Oct 11, 2004 | 02:11 PM
Pete_SI's Avatar
Default Re: IHI RHB5 (tjbizzo)
That's the solenoid I was talking about, you can see the wire...This is not my actual turbo I took this picture off homemadeturbo.com. I will get a picture of mine as soon as I get a camera.
Old Oct 12, 2004 | 11:49 AM
Pete_SI's Avatar
Old Oct 12, 2004 | 12:01 PM
wantboost's Avatar
Who is Mr Robot?
looks like a factory bost control solenoid.
Pete_SI's Avatar
Default Re: IHI RHB5 (wantboost)
Could I take it out or even use it?
Old Oct 12, 2004 | 12:05 PM
tgreaves's Avatar
Not sure if it can be taken out.. But it can be bypassed.. Just connect the nipple from the wastegate to the nipple on the compressor housing.. Or better yet, connect the nipple from the wastegate to the intake manifold and plug the nipple on the compressor housing..
Old Oct 12, 2004 | 12:16 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: IHI RHB5 (tgreaves)
it was probably wired up to a pressure sensor that closed the circuit when it reached a certain boost level. If you could find some way of testing it, maybe with a battery and an air hose or something, and if it worked, just go buy a hobbs switch, adjust it to the boost you want to run, an volia! HMT Boost controller for almost no cash.
Old Oct 12, 2004 | 12:21 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">it was probably wired up to a pressure sensor that closed the circuit when it reached a certain boost level. If you could find some way of testing it, maybe with a battery and an air hose or something, and if it worked, just go buy a hobbs switch, adjust it to the boost you want to run, an volia! HMT Boost controller for almost no cash.</TD></TR></TABLE>
Usally something like this is a PWM.. I would assume that you would need to find a frequency to operate it at to allow boost to enter to be vented from the line..
This is how the GM boost noid works but im not sure about this one..
Old Oct 12, 2004 | 12:57 PM
.nate's Avatar
I'm pretty sure you can unbolt that crap from the turbo... It's been a while since Ive messed with a RHB5
Old Oct 12, 2004 | 01:05 PM
MooreBoost's Avatar
Default Re: IHI RHB5 (.nate)
Yeah, it can be unbolted, mine never had that.
Is this for your bike?
Old Oct 12, 2004 | 01:06 PM
tgreaves's Avatar
Im almost positive you can unbolt it and remove it.. Either way you can bypass it..
Old Oct 12, 2004 | 01:12 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
i jsut got that turbo out of a junkyard the other day and i took teh solenoid off by accident and left it there. oh well, i dont think u need it anyway. i scored that turbo, mx-6 front mount, bov, and intercooler piping for $60
Old Oct 12, 2004 | 01:27 PM
tgreaves's Avatar
Default Re: IHI RHB5 (91siredrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91siredrex &raquo;</TD></TR><TR><TD CLASS="quote">i scored that turbo, mx-6 front mount, bov, and intercooler piping for $60 </TD></TR></TABLE>
Gotta love that.. I got my Garrett/Airesearch T3 .48/.42 from the junkyard for $50 and I got an intercooler for $20.. The guy at the junkyard was pissed because the intercooler was brand new and he didnt see it to pull it before hand..
Old Oct 12, 2004 | 02:32 PM
Pete_SI's Avatar
Default Re: IHI RHB5 (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">
Is this for your bike?</TD></TR></TABLE>
haha no but that would be crazy
I'm looking forward to do a single slamer turbo. I want to get into so I thought I would start slowly.
BTW thanks for the info guys.
Old Oct 13, 2004 | 06:09 PM
.nate's Avatar
It's aight wont make more then about 14.5 lbs of boost and thats blowing hot air. Its a fun little turbo for a first setup. THe biggest prob I has was with the oil pressure blowint the seals on the turbo :/
Old Oct 14, 2004 | 05:19 AM
tgreaves's Avatar
Default Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">It's aight wont make more then about 14.5 lbs of boost and thats blowing hot air. Its a fun little turbo for a first setup. THe biggest prob I has was with the oil pressure blowint the seals on the turbo :/ </TD></TR></TABLE>
You might need to put an oil restrictor on the turbo.. Either that or the seals in the turbo are gone..
Old Oct 14, 2004 | 01:15 PM
Pete_SI's Avatar
Default Re: (tgreaves)
I just used this turbo because I get it pretty cheap and want to start of easy. How could I know if the seals are gone.
Psychoteen101
Mar 10, 2015 01:17 PM
underpressure02
May 13, 2008 07:52 AM
redsikiller
Oct 17, 2005 02:49 AM
96ex
Jun 30, 2005 05:33 AM
BoostedD15B7
Dec 8, 2002 05:30 PM
