Anyone strip threads on exhaust housing?
Old 10-10-2004, 05:16 PM
2muchPSI's Avatar
Default Anyone strip threads on exhaust housing?
Well, the threads that should bolt up my downpipe to my turbo are all FUBAR. What are my options to get them fixed?
I really don't want to helicoil them, due to cost. I was thinking maybe i could put studs in 2 or 3 of the 5 bolts? If you have any experience with this or any information that could help please post. Thanks!
Old 10-11-2004, 03:30 PM
2muchPSI's Avatar
Default Re: Anyone strip threads on exhaust housing? (2muchPSI)
bump
Old 10-11-2004, 03:45 PM
willahlborn's Avatar
http://www.homemadeturbo.com/f...23117
Turbo to downpipe stud kit. Your welcome
Old 10-11-2004, 03:46 PM
vaporboy12's Avatar
tap them bitchs out
93turbo16's Avatar
^ you win
yea, or just try to run a tap through it to clean them up.
Old 10-11-2004, 04:35 PM
rmcdaniels's Avatar
I had that problem, ran a tap through them to clean them up and got a little longer bolts, works great.
Old 10-11-2004, 05:48 PM
2muchPSI's Avatar
Default Re: Anyone strip threads on exhaust housing? (rmcdaniels)
My problem is there are no threads left in the holes. I can't just screw a stud in, and they are bad enough that a tap isn't going to help at all.
Old 10-11-2004, 08:59 PM
ILLICON3000's Avatar
send it to tims turbos I t hink he retaps for 5 a hole
http://www.timsturbos.com
Old 10-12-2004, 03:50 PM
2muchPSI's Avatar
Default Re: (ILLICON3000)
I try to be a DIYer as much as I can. I don't understand how he is gonna retap it, when there are no threads at all? What exactly would he be doing to fix it, cause chances are I can do it too, saving some money and time.
Old 10-12-2004, 04:20 PM
JeffS's Avatar
Default Re: (2muchPSI)
Having threads doesn't have anything to do with tapping the hole...
Technically, if you've got threads, you're chasing the threads, not tapping them anyway. You would be tapping to a size up from what you were originally using. In this case, there's no point in trying to repair it back to the original size with something like a helicoil.
BlackBeastEK
01-24-2007 06:23 PM
projectPSI
07-21-2004 07:57 AM
cyphergs-r
01-17-2003 04:31 AM
tbkonwso
09-17-2002 10:44 PM
B18C-RnVA
09-15-2002 06:59 PM
Quick Reply: Anyone strip threads on exhaust housing?
