Interesting article about exhaust sizing
Old Oct 13, 2004 | 03:57 PM
Stewie's Avatar
Default Interesting article about exhaust sizing
I came across this article from turbo magazine.
http://www.turbomagazine.com/t...aust/
This is the gain from switching to a 3" exhaust. Could it be attributed to the fuel management?
let me know what you think
Old Oct 13, 2004 | 04:08 PM
EJ1 wilcox's Avatar
Default Re: Interesting article about exhaust sizing (Stewie)
Hmmmm.... interesting....
You would think that going from 2.25 to 3 inches would really free up the flow from the turbo...
I'm thinking maybe 2.25 is fine for the less than 200 hp that the car was making. I would think that you would be better off with a 3 inch if you are wanting 200+...
Plus, they only ran the test at 7psi and a FMU... ( I don't know why you would only run 7psi on a fully built motor!)
I bet if they did the test at 14psi the increase would be much much more significant with a 3 inch exhaust...
Old Oct 13, 2004 | 04:10 PM
stizzit's Avatar
Interesting, i think its a good start.
I would love to see someone test several different increments of piping, specifically 2.5" to 3" to 4".
I'm currently trying to decide whether a 4" DP is going to be more trouble than its worth as compared to a 3".
for other input
Muckman's Avatar
Moderator in Chief
I expected a bigger gain going from 2.25" to 3" on a turbo car.
Is that an EGT probe on that guys intercooler piping?
Old Oct 13, 2004 | 04:12 PM
FOrSfEd's Avatar
Default Re: Interesting article about exhaust sizing (EJ1 wilcox)
I would have to agree, if the boost was tunred up and it was creating a lot more flow then I think the power increase would be a lot noticable though the increase they showed was not bad considering the car, motor, and turbo they were using.
Old Oct 13, 2004 | 04:15 PM
Rory Breaker's Avatar
Default Re: Interesting article about exhaust sizing (FOrSfEd)
I'll have my dyno up soon of 60mm to 3" turboback (and a manifold change - drag to IP).
No peak difference, 5-15whp and wtq gain from 4-6500. There were some small differences though...some maintenance items, and my downpipe sitting on one of my charge pipes. Ill go back soon with those fixed and post the graph.
kou-integra98
Oct 11, 2013 07:20 AM
ChewiSi
Dec 25, 2005 05:25 PM
scatuli
Nov 21, 2003 05:12 AM
fOmaNPu
Apr 6, 2003 10:57 AM
LOwrestling2001
Dec 8, 2002 08:38 PM
