Proper intercooler piping size
Old Oct 13, 2004 | 03:44 PM
MidShipCivic's Avatar
Default Proper intercooler piping size
Should the pipe size match the compressor outlet?
Old Oct 13, 2004 | 03:48 PM
PrecisionH23a's Avatar
Default Re: Proper intercooler piping size (MidShipCivic)
On E housings I run 2.25" IC piping and on S housings I run 2.5".
That's a pretty good rule of thumb right there.
Old Oct 13, 2004 | 03:51 PM
Nobody Special's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">Should the pipe size match the compressor outlet?</TD></TR></TABLE>
depends on a hell of a lot of variables - specifically what cfm you plan to run, but remember that the IC causes a pressure drop. Large diamater piping also causes a pressure drop. Of course - if you need this increased diamater to flow at higher RPM or you drive around at a higher CFM - then you're set. If not - then downsize. But...good luck getting your BLinG points with slimmer piping that'll keep those flow rates high and lag low with torque up.
jbell
Nov 15, 2008 12:54 PM
blackpearlcivic
Nov 17, 2005 05:02 AM
Soon_2b_evil
Aug 20, 2003 08:33 AM
FredoSP
Jul 11, 2003 03:15 AM
HuskerHybrid
Jul 10, 2003 11:38 AM
