is it possible to tap here for an oil temp sending unit???
just wondering if i can put the sender for an autometer oil temp gauge in this spot on the head. i know it gets oil in it and doesnt get in the way of moving parts. anyone done it before?
Re: is it possible to tap here for an oil temp sending unit??? (blackeg)
i believe if you tap it there. you will only see oil pressure when vtec comes on
Re: is it possible to tap here for an oil temp sending unit??? (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">Just tap the pan, easier IMO. I had mine tap'd n tig'd w/ a bung for $20!
Blaze</TD></TR></TABLE>
you tapped the oil pan for the pressure sender?
Re: is it possible to tap here for an oil temp sending unit??? (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">
you tapped the oil pan for the pressure sender?</TD></TR></TABLE>
nah he said *temp* sender
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">Wait.... it is for an oil temp sender.... lol </TD></TR></TABLE>
hahaha
hahaha
Re: is it possible to tap here for an oil temp sending unit??? (turbotime)
hahahaha. temperature! oil temp.
anyhow, the T thats currently being used off the back of the block is all full and i dont feel like making a huge contraption of brass fittings, or even than buying another T haha
The standard that people generally go by is oil pan temperature.The oil temperature varies in the engine, so if you measure it elsewhere it will be hard to compare with others that measure it in the pan.I've tapped the drain plug before (in the side of the pan,not the bottom).It just a pain when you change the oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">hahahaha. temperature! oil temp.
anyhow, the T thats currently being used off the back of the block is all full and i dont feel like making a huge contraption of brass fittings, or even than buying another T haha</TD></TR></TABLE>
You need an oil filter sandwich.
Re: is it possible to tap here for an oil temp sending unit??? (Sleeper Style)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style »</TD></TR><TR><TD CLASS="quote">
You need an oil filter sandwich. </TD></TR></TABLE>
ya i have on on my car. its badass but i use the an fitting for my lsvtec oil feed. this car is a gsr...do they sell a plug for that an larger hole?
DC4_MADMAN
05-26-2006 01:37 PM
