Anyone using an AEM 3.5 Bar map sensor?
Old Jul 27, 2006 | 11:41 AM
nebulight's Avatar
Default Anyone using an AEM 3.5 Bar map sensor?
Here is my setup:
Full-Race Prostreet Manifold
3 inch DP
Tial BOV
Tial 44mm Wastegate
SC6152e .63a/r
Precision 1000cc Injectors
Precision Medium IC
Edelbrock Victor X Intake Manifold
2.5inch IC pipes
Stock GSR TB
AEM 3.5bar map sensor
Competition Clutch Twin Disc
Stock Block/Head with ARP head studs
When I finally get everything on the car, I'm going to get it tuned by Jeff Evans using Neptune. I'm just going to run low boost ~10psi until I can afford to get a sleeved block then up the boost to take advantage of the 3.5 bar map sensor. Now I know that Neptune can handle up to a 5 bar map sensor, but I see a lot of people that run 30+ psi with just a normal GM 3bar sensor. Should I have just gotten a 3 bar?
Also, how does the 3.5 do on low boost settings? I had some concerns with using that map with my 1000cc injectors with low boost. Any input?
Old Jul 27, 2006 | 12:03 PM
locash's Avatar
Default Re: Anyone using an AEM 3.5 Bar map sensor? (nebulight)
Considering that the 3 bar map sensor only reads up to about 29.4 psi, it would not be a good idea to run 30+ psi when using it..
Old Jul 27, 2006 | 12:18 PM
nebulight's Avatar
Default Re: Anyone using an AEM 3.5 Bar map sensor? (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">Considering that the 3 bar map sensor only reads up to about 29.4 psi, it would not be a good idea to run 30+ psi when using it.. </TD></TR></TABLE>
Exactly my point, but I see people doing it...
http://forums.evans-tuning.com...=3622
http://forums.evans-tuning.com...=3404
Old Jul 27, 2006 | 02:19 PM
underpressure02's Avatar
I don't understand your question or problem? Why would the sensor not do good on low boost? Just because it can read 3.5 bar does not mean it will have trouble reading 10psi. You just won't have as much resolution on your map with the higher the map sensor you go with.
Old Jul 27, 2006 | 03:51 PM
nickromeo's Avatar
Default Re: Anyone using an AEM 3.5 Bar map sensor? (underpressure02)
im pretty sure neptune has expanded maps for pretty high resolution
insaneconceptz
Mar 4, 2009 05:35 AM
justa4dr
May 17, 2008 11:49 AM
laziebun
Jan 14, 2008 04:58 AM
LSEGHATCH
Oct 24, 2005 10:12 AM
Beer
Jun 19, 2002 11:44 PM
