turbo overspin?
Old Aug 1, 2006 | 02:49 PM
whoneedzvtec's Avatar
Default turbo overspin?
whats up fellas, so i am re-doing my whole setup but to make a long story short i am switching from a ramhorn manifold to a topmount and i have to drive about 60 miles to my friends house to get the charge pipes done. under normal driving conditions would this overspin the turbo being as there is no charge pipes on it? also it is a brand new turbo, turbonetics tomzilla from camp1320. thanks in advance.
Old Aug 1, 2006 | 02:56 PM
nickromeo's Avatar
Default Re: turbo overspin? (whoneedzvtec)
if u absolutely have to, and there is no way around driving, remove the wastegate spring for external wastegate. that way the wastegate will
be open and as much exhaust gas as possible will bypass the turbine
Old Aug 1, 2006 | 02:58 PM
nickromeo's Avatar
Default Re: turbo overspin? (nickromeo)
stay in vaccuum and keep the revs as low as humanly possible also
Old Aug 2, 2006 | 11:28 AM
elevatedj32's Avatar
This poses a question that hopefully some of you more experienced turbo guys can answer. On two occasions, i've blown off the silicon coupler which just causes the turbo to spin out of control. When it happened, I was under WOT at the top of the rpm range. I knew what happened when I lost boost.
Everything seems normal after that and have since corrected the problem.
What are some of the consequences when this happens?
Old Aug 3, 2006 | 06:40 PM
Default Re: turbo overspin? (elevatedj32)
anybody else have any info on this? thanks
turb0teg
Aug 25, 2010 08:56 PM
Dan_the_MaN
Oct 5, 2005 12:08 AM
AzntaggeR
Apr 28, 2005 08:11 PM
1.8Tities
Apr 5, 2003 11:01 AM
B20-T
Jul 28, 2002 12:39 AM
