Broken d16 dohc, what caused this?
Old Jul 27, 2006 | 03:44 PM
joppezz's Avatar
Default Broken d16 dohc, what caused this?
Setup:
Engine: d16a9 dohc, wiseco, eagle, blockguard, stock sleeves
Head: some headwork done, crespo stage2 cams, crespo springs
FI: revhard stage 3 (precision sc50, turbine .48)
Fuel: Walbro 341, stock lines, aem rail+fpr, 680cc injectors, ems turboedit + gm3bar
Used on tuning: Innovate lm1+xd1, autometer egt gauge
I have tuned it by myself in streets with first setup, ~8:1cr and 27psi of boost daily with no problems in engine, about 12K miles. Then i changed headgasket to thicker and cr raised to 8.5-8.6, I lower ignition map by few degrees. Drive about 100miles with 12psi, and had problem with ignition, more boost than 12psi it started to run with 3 cylinders or something, no power at all. Then gapped plugs about 0.28, started to ignite on higher boost. I drive with 3 gear 4000->8000rpm, it runs fine, then i dropped speed back to ~60mph and motor is now running maybe 2 cylinder, i drive to side of the road, and we towed car to the garage, this is what found:
http://hanza.1g.fi/kuvat/civic/
Afr was rich, about 11.2 egt was low as 1400F max (probe in dp) fuel was
shell v-power (93octane) im not sure how much boost i runned, maybe 20psi but something happened with boost at the end off pull because autometer boostgauge line was go off from intakemanifold. Plugs was bcpr 7es-11 (Too hot)
Cylinder 1 is that who lose a retainer. Why?
What caused these little marks on pistons and head, detonation? Pre ign? Or something **** through the intake (i have filter)
2 and 3 cylinder plugs gap was closed (can detonation do this?)
Cylinder4 seems to be ok, and headgasket d16z6 modified was ok too.
Thanks for answers.
Old Jul 27, 2006 | 05:13 PM
turbotime's Avatar
looks like piston to valve contact + detonation or something? Im not sure but i know that the valve should be closed in this pic not 1 open 1 closed so something is definitely wrong with the head/valvetrain
Old Jul 27, 2006 | 05:21 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Broken d16 dohc, what caused this? (joppezz)
if youre reading 1400 degrees in the downpipe, thats too effing hot
Old Jul 28, 2006 | 01:16 PM
joppezz's Avatar
Help please. some pictures more:
http://personal.inet.fi/cool/joppe2/paskana11.jpg
http://personal.inet.fi/cool/joppe2/paskana3.jpg
http://personal.inet.fi/cool/joppe2/paskana13.jpg
And video just before it broke
http://personal.inet.fi/cool/joppe2/hajos.avi
Modified by joppezz at 12:17 PM 7/29/2006
Old Jul 28, 2006 | 01:53 PM
90teg's Avatar
Did you have an air filter on the turbo?
Old Jul 28, 2006 | 02:16 PM
TypeSLO's Avatar
Default Re: (90teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joppezz &raquo;</TD></TR><TR><TD CLASS="quote">Or something **** through the intake (i have filter)
how's the valvetrain look?
Old Jul 28, 2006 | 07:26 PM
AIRIC's Avatar
Default Re: (TypeSLO)
i love the dohc d16 that **** is bad ***
Old Jul 29, 2006 | 03:43 AM
joppezz's Avatar
Can piston like this use?
http://personal.inet.fi/cool/joppe2/manta4.jpg
Old Jul 29, 2006 | 05:54 AM
grndcont's Avatar
the same thing happend to my buddys ride, retainer broke for no damn reason, it sucks. no you caint reuse any of that ****. the nicks are from **** that broke off and bounced around in there. have fun with the rebuild. and remember, a thicker head gasket will lower compression.
Old Jul 29, 2006 | 11:18 AM
joppezz's Avatar
I went to lower head gasket. Sorry for typo. Trust 2mm to OEM 1mm
Old Jul 29, 2006 | 12:29 PM
RedR's Avatar
Default Re: Broken d16 dohc, what caused this? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">if youre reading 1400 degrees in the downpipe, thats too effing hot</TD></TR></TABLE>
Old Jul 29, 2006 | 03:18 PM
dunkd's Avatar
are those oem retainers?
Old Jul 29, 2006 | 09:30 PM
joppezz's Avatar
So you think those piston are melted? Yes, they are oem retainers
Old Jul 29, 2006 | 09:36 PM
dunkd's Avatar
Default Re: (joppezz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joppezz &raquo;</TD></TR><TR><TD CLASS="quote">So you think those piston are melted? Yes, they are oem retainers </TD></TR></TABLE>
were you revving past oem redline?
Old Jul 29, 2006 | 09:40 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (dunkd)
if you over revved on stock valvetrain i could seee a valve floating and the piston smacking the valve.
Old Jul 29, 2006 | 10:41 PM
xxxmikenicexxx's Avatar
Default Re: (wantboost)
Like someone asked, was there a filter on the turbo? Due to the damage to the turbo, Im leaning towards sand or something similar being sucked into the turbo/engine. See how theres much more damage on the middle two cylinders? That could be because as they were in the intake stroke something was sucked into the engine and didnt cause as much damage on the other cylinders as they were on a different stroke. Due to the tiny pits, Im not thinking piston-to-valve..do you have pics of the rest of the valves? That may help us out here. Im sorry to say, but with that damage nothing is reusable, it will cause extreme hot spots and nothing but trouble. I really hate to see stuff like this it really sucks Let us help you out here and we will find the cause and make sure it doesnt happen again
Old Jul 30, 2006 | 12:39 AM
joppezz's Avatar
Turbinewheel has little damage, compressor is 100% ok and compressorhouse is ok too. Yes i have
filter in turbo, 200miles used now. Here is some pictures of head:
http://personal.inet.fi/cool/joppe2/cylinder1.jpg
http://personal.inet.fi/cool/joppe2/cylinder2.jpg
http://personal.inet.fi/cool/joppe2/cylinder3.jpg
http://personal.inet.fi/cool/joppe2/cylinder4.jpg
http://personal.inet.fi/cool/j...3.jpg
With OEM valvetrain and crespostage2 cams i used 8K revlimit 10K miles. With crespo valvesprings i rev 8.5K.
Old Jul 30, 2006 | 08:03 AM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joppezz &raquo;</TD></TR><TR><TD CLASS="quote">With OEM valvetrain and crespostage2 cams i used 8K revlimit 10K miles. With crespo valvesprings i rev 8.5K. </TD></TR></TABLE>
so you had aftermarket cams and valve srings, but oem retainers? stock redline is 7200 right? I bet too much overreving just caused that retainer to break and allow metal particles into the combustion chamber causing all of those marks. did you find any other broken metal besides that retainer?
Old Jul 30, 2006 | 08:13 AM
blackeg's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">
so you had aftermarket cams and valve srings, but oem retainers? stock redline is 7200 right? I bet too much overreving just caused that retainer to break and allow metal particles into the combustion chamber causing all of those marks. </TD></TR></TABLE>
sounds like a very reasonable sequence of events...
sorry to see that happen. grab a new head and set of pistons and your back in action
Old Jul 30, 2006 | 10:02 AM
Flashmn's Avatar
Default Re: (blackeg)
Yeah, I second the overreving past redline and thus causing the problems. If the turbineside is ok, then you can pretty much discount the foreign object damage and that damage came from stuff inside the engine.
Good luck rebuilding it.
rfelix89
Sep 20, 2012 11:43 PM
LST2
Jul 10, 2007 06:15 PM
ahemming06
14
Apr 17, 2006 09:51 PM
97turboteg
Apr 7, 2006 07:28 AM
Trailz-EX
Sep 27, 2004 08:28 PM
