what bends are needed to build a 3" exhaust on a eg hatch?
i have a eg hatch and want to build an exhaust system because im going turbo. i want to figure out all the bends i need before i go to summit though and i dont have access to my car at the moment. can anyone help me out? o and this is just a catback, i already have everything needed for the downpipe
i dont have access to my car....therefor i cant draw it out.......i know i need 1 u for the 2 90's and a u for the hump over the rear lca, but do i need anything else?
Re: what bends are needed to build a 3" exhaust on a eg hatch? (xtremeazian)
Good call on the two U-bends. That works out perfect.
Basically you need 360 degrees of bends to make an exhaust for most honda's (EG, DC, EK)
Cut one of the 180s in half. That covers the two 90 bends. The other 180 will be cut into a 90 (from the middle) and two 45s. That covers the hump.
Re: what bends are needed to build a 3" exhaust on a eg hatch? (F20Cteg)
I think you might need 3 if you plan on making a downpipe also. I think jcwhitney is cheaper than summit. good luck
racing solutions has good prices on bends i bought there exhaust builder kit it has 2 45s 2 90s and 2 180s i didnt even use all of the 180s just a small section for the turndown at the end all that for about $70.00 shipped then buy a straight section from summit for about $12.00
I don`t know how many bends other guys used but I just made a 3" inch cat back exhaust on my Integra and I used 5 bends that are 90* (degrees) and about 15 feet of stright pipe.
B A N N E D
Location: Orange County / Palm Springs 714/76hoe, ca, usa
Re: what bends are needed to build a 3" exhaust on a eg hatch? (eastbay92cx)
i bought i exhaust builder from racing solution for 70 ish shipped to my door
check store.racing-solutions.org
Re: (Marlon88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marlon88 »</TD></TR><TR><TD CLASS="quote">I don`t know how many bends other guys used but I just made a 3" inch cat back exhaust on my Integra and I used 5 bends that are 90* (degrees) and about 15 feet of stright pipe.</TD></TR></TABLE>
Why did you need so much straight piping? You probably had hella left over
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon95eg »</TD></TR><TR><TD CLASS="quote">i bought i exhaust builder from racing solution for 70 ish shipped to my door
check store.racing-solutions.org </TD></TR></TABLE>
Re: (xtremeazian)
Why not just get a piping kit from Kteller? All it needs is to be welded in place. It's about $200 and top notch quality. Anyways, you will need about 4-5 90 bends (depends how u cut them) and about 8 feet of piping
Adriano
Adriano
well i could just buy two u bends for like $45 shipped then buy a magnaflow 3" for $75 and i already have the straight, so it would actually be much cheaper to not go that route.
