dsm injector question
Old Jul 28, 2006 | 09:07 PM
95dc2teg's Avatar
Default dsm injector question
I have an 95 Integra gsr with obd1. I want to run dsm 450's. I know that you have to have a resistor box which I have and that you have to modify a o ring for it to fit in correctly. What about injector clips? will i need dsm injector clips or will the integra clips work. What else do i need besides the resister box, modified oring and injectors? Any help would be appreciated.
Old Jul 28, 2006 | 09:43 PM
Kowalski's Avatar
Default Re: dsm injector question (95dc2teg)
I didn't need to modify the O-Ring... Just lubed it up and slid that ish in. Your OBD-1 Clips will work. There are a ton of threads on DSM Injectors - they should answer all your questions.
https://honda-tech.com/zerothread?id=884048
https://honda-tech.com/zerothread?id=195834
Old Jul 28, 2006 | 11:17 PM
Mr.Death's Avatar
Default Re: dsm injector question (Kowalski)
My DSM injectors plugged in with no issues at all. Straight up replacement.
Old Jul 29, 2006 | 04:24 AM
0618turbocivic's Avatar
theres a lil keyway on the 40's you might have to cut that keyway out and they plug right in
Old Jul 29, 2006 | 06:20 PM
HondAcura's Avatar
Default Re: dsm injector question (0618turbocivic)
You can run honda resistor box, dsm resitor box-you can even make one from radio shack-if you're so electronically inclined-
Here- https://honda-tech.com/zerothread?id=441107
The stock clips fit
The dsm injector o-rings should fit without too much trouble
Obviously the stock untouched Ecu wasn't designed to idle and run 450's so make sure you're okay there
Modified by HondAcura at 6:03 PM 7/30/2006
Old Jul 29, 2006 | 11:01 PM
95dc2teg's Avatar
Default Re: dsm injector question (HondAcura)
alright thanks for the info guys. They were put in with no problems.
Civiclx
May 11, 2007 08:36 AM
b17a1crx
Sep 10, 2006 07:27 PM
petergriffen
Jul 17, 2006 08:48 AM
Smooth-GSR
Mar 26, 2004 10:16 PM
Happyman
Jul 7, 2003 06:37 AM
