squirters question
Old Jul 31, 2006 | 09:30 AM
kebroz's Avatar
Default squirters question
Anybody had problems of breakage of squirters??
I saw on another forum than some guys remove them on the build engines.
i've a darton sleeved B16 with wiseco pistons and eagle rods, i looking for apprx 9200/9500rpm (15psi max)
all opinions are goods for me
thanks.
Old Jul 31, 2006 | 10:04 AM
Muckman's Avatar
Moderator in Chief
Default Re: squirters question (kebroz)
breakage? the only problem ive encountered with them is clearance issues with the counterweights of longer stroke cranks. But you can file the corner of the bolt head and it will clear.
Alot of people on this board plug them because its not needed with forged pistons as they run cooler anyways. I run squiters with forged pistons for the hell of it.
Old Jul 31, 2006 | 10:09 AM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kebroz &raquo;</TD></TR><TR><TD CLASS="quote">Anybody had problems of breakage of squirters??
thanks.</TD></TR></TABLE>
People remove them because they feel forged aluminium disspates heat better than stock cast pistons therefore its not needed and plugging them bumps up the oil pressure, but thats hogwash to me. keep your squirters in.
Old Jul 31, 2006 | 10:54 AM
TypeSLO's Avatar
Default Re: squirters question (Boostage)
the oil does not cool the pistons that much. the reason why the forged aluminum pistons keep cooler is because they transfer heat better. that's how the majority of the pistons and cylinders are cooled, transfer the heat to the water jacket. and some people who are looking for the little extra squeeze out of their motors take out the squirters because they create more reciprocating mass, makes the pistons "heavier" which can rob a little power. only real application for this imo is drag racing.
Old Jul 31, 2006 | 11:04 AM
rwcdrums's Avatar
Default Re: squirters question (TypeSLO)
I just bought a erl built block with the oil squiters plugged.
Old Aug 1, 2006 | 05:39 AM
kebroz's Avatar
Thank you has all, you confirm my opinion, I think that the guy who broke his squirters, his problem is other one than the oil pressure in the very high rpm.
I keep mine.
Old Aug 1, 2006 | 06:15 AM
DJ Gurgla GSR's Avatar
Default Re: (kebroz)
here's my two cents. not getting into the whole argument of whether to keep them or not
i had clearance issues with the wiseco piston skirt and the oem squirters. so i bent them to fit properly. You may / may not have the same problem but its something to keep in mind...
RACEPAK
Oct 20, 2014 07:37 PM
Flixz27
Jun 22, 2012 11:06 AM
Yambor
May 30, 2006 08:59 AM
dustin
Jan 10, 2006 08:12 PM
allmotor99lude
Jan 4, 2006 11:37 AM
