ecu test
Old Jul 30, 2006 | 10:44 PM
TypeSLO's Avatar
Default ecu test
i'm not sure if this belongs here or not but i picked up a p28 for free from honda. it's used and been sitting on a shelf. they pulled it from a car but they didnt' know the history of it. i'm only looking to sell it but i'm reluctant because i don't know if it actually works. how do i test the ecu? i'm gonna try to stop by honda to see if maybe they can test it but with my work schedule, it's hard to make it there on time before they close. please help. thanks.
Old Jul 31, 2006 | 12:23 AM
mtber's Avatar
Default Re: ecu test (TypeSLO)
Plug the ecu into a obd1 car or a car with a obd1 conversion harness. Turn the ignition onto the acc. position, if the mil turns on then turns off, the ecu is working properly.
If the mil turns on and stays on & the mil stays solid while jumping the 2 wire srs connector the ecu is malfunctioning.
Old Jul 31, 2006 | 12:37 AM
njcrxsi's Avatar
Default Re: ecu test (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Plug the ecu into a obd1 car or a car with a obd1 conversion harness. Turn the ignition onto the acc. position, if the mil turns on then turns off, the ecu is working properly.
If the mil turns on and stays on & the mil stays solid while jumping the 2 wire srs connector the ecu is malfunctioning. </TD></TR></TABLE>
mil ?
Old Jul 31, 2006 | 12:55 AM
mtber's Avatar
Default Re: ecu test (njcrxsi)
Check engine light.
Old Jul 31, 2006 | 12:56 AM
njcrxsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Check engine light.</TD></TR></TABLE>
oh my bad.. im used to cel
Old Jul 31, 2006 | 04:29 AM
TypeSLO's Avatar
wow. that's much simpler than i expected. someone else told me that they have to have the right equipment and run a few tests. thanks for your help.
7rrivera7
Jul 31, 2008 05:03 PM
CeeJayy
Jul 27, 2007 07:48 PM
big-cat
26
Oct 19, 2006 11:14 AM
bonylad
Sep 26, 2005 03:53 AM
Jbunn2001
Jul 26, 2005 07:31 PM
