blown head gasket 10 min after start up?
just what it says put engine together got all air pockets out of the motor pull it out of the shop not passing 3000rpms and next i hear gurgling from the over flow can, pop top off the radiator and top it off(coolant) nothing but tiny air bubbles and over heating after 1500rpms has this happened to anyone?
Re: blown head gasket 10 min after start up? (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Head gasket upside down?</TD></TR></TABLE>
and any leaks? coolant or oil?
Re: blown head gasket 10 min after start up? (Day-DayC)
HEAD GASKET WAS CORRECT, BLOCK WAS JUST SLEEVED, HEAD WAS JUST MACHINED. ITS ON A LS/VTEC. IM PULLING THE HEAD OFF MONDAY. ITS JUST A LTTLE PUZZELING
did a leak down test shows good no bubbles from the radiator what gives im in the dark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Day-DayC »</TD></TR><TR><TD CLASS="quote">did a leak down test shows good no bubbles from the radiator what gives im in the dark</TD></TR></TABLE>
50/50 coolant mix? Air bled from system? T-stat good? Rad cap leaking?
FOUND THE OVER HEATING ISSUE THE TWO HOSES ON THE BACK OF THE MOTOR WAS CROSSED BUT STILL HAVE THE GURGLING THING AND AT MOMENTS IT THROWS UP COOLANT
Squirtin EGsr
17
09-26-2005 09:13 PM
