Sleeved GSR or LS block?
Old Jul 31, 2006 | 02:57 AM
faSHOwidIT's Avatar
Default Sleeved GSR or LS block?
Lets say you have to pick which one to get sleeved, which block would you choose? I was thinking a ls block for the bigger crank but gsr for the oil squirters. I heard when you run Arias pistons and other pistons of the same material, oil squirters isn't even necessary. I can't decide wether to sleeve my gsr block or ls block. Pick one. Of course LS will be ls/vtec. I searched and didn't find anything.
Old Jul 31, 2006 | 03:25 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Sleeved GSR or LS block? (faSHOwidIT)
gsr, simple, done.
Old Jul 31, 2006 | 03:47 AM
Schister66's Avatar
Man U FTW
^^agreed
Old Jul 31, 2006 | 03:58 AM
faSHOwidIT's Avatar
Default Re: (Schister66)
and the reasons for picking the gsr?
Old Jul 31, 2006 | 04:15 AM
BoostedEG6's Avatar
Default Re: (faSHOwidIT)
GSR block with LS internals (ie crank, rods, pistons)
Old Jul 31, 2006 | 04:23 AM
gmacarize's Avatar
well you could do both... run an ls crank in the gsr block...
Old Jul 31, 2006 | 05:10 AM
jcintegratyper's Avatar
use the gsr block because of the oil squirters and use the ls crank because of the stroke.
Old Jul 31, 2006 | 07:46 AM
eg crunkmonster's Avatar
Default Re: Sleeved GSR or LS block? (jcintegratyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcintegratyper &raquo;</TD></TR><TR><TD CLASS="quote">use the gsr block because of the oil squirters and use the ls crank because of the stroke. </TD></TR></TABLE>
u dont need the oil squirters with forged pistons
get a sleeved gsr so u dont have to waste money on an LSVTEC kit.
Old Jul 31, 2006 | 07:55 AM
Zakar's Avatar
Default Re: Sleeved GSR or LS block? (eg crunkmonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg crunkmonster &raquo;</TD></TR><TR><TD CLASS="quote">
get a sleeved gsr so u dont have to waste money on an LSVTEC kit. </TD></TR></TABLE>
Exactly.. doesnt the GSR have a factory girdle too?
Old Jul 31, 2006 | 08:24 AM
96 GSR-T's Avatar
Default Re: Sleeved GSR or LS block? (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly.. doesnt the GSR have a factory girdle too?</TD></TR></TABLE>
Yup
Old Jul 31, 2006 | 09:04 AM
chrisgottigsr's Avatar
keep your gsr block
Old Jul 31, 2006 | 01:26 PM
Topdawgg's Avatar
the GSR is alot stronger... like it was said, because of the girdle..
Old Jul 31, 2006 | 04:34 PM
faSHOwidIT's Avatar
Default Re: (Topdawgg)
so gsr with LS crank? i already got all the stuff for ls/vtec so it doesn't really matter.
Old Jul 31, 2006 | 04:40 PM
then sleeve the LS block and sell the GSR since its worth more money. the girdle is worthless imo, ive seen a lot of people do prefectly fine without one. oil squirters are not needed for ur forged pistons.
Old Aug 1, 2006 | 07:07 AM
faSHOwidIT's Avatar
Default Re: (eg crunkmonster)
bump
Old Aug 2, 2006 | 03:24 AM
faSHOwidIT's Avatar
any problems with LS motors revving high without a girdle?
Old Aug 2, 2006 | 04:21 AM
hotimportcrx's Avatar
Keep the gsr block just so you dont have to run that external oil line....especially since you will be turbo you dont want a million lines back there (vtec oil, turbo feed, oil pressure)...i would just use the gsr block....it has oil squirters as well but there pointless on a built motor, they help cool a cast piston but since you will be forged which can take alot more heat dont worry about it.
Old Aug 2, 2006 | 04:40 AM
86si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg crunkmonster &raquo;</TD></TR><TR><TD CLASS="quote">then sleeve the LS block and sell the GSR since its worth more money. the girdle is worthless imo, ive seen a lot of people do prefectly fine without one. oil squirters are not needed for ur forged pistons. </TD></TR></TABLE>
perfectly fine making small power maybe. 10k rpms and 5-600whp i would feel alot safer with a girdle.the gsr block is better period.
vpower101
Jan 21, 2008 10:47 AM
EK FLY
Jan 27, 2005 10:57 PM
typeRSXS
Mar 24, 2004 03:54 PM
Jared
Jul 10, 2001 01:12 PM
