Weird CEL and fuel cut
Old Jul 31, 2006 | 02:21 PM
SOHC_MShue's Avatar
Default Weird CEL and fuel cut
So Just the other day my car started to fuel cut real early at 6 or 7k rpms under boost. Whats strange is that it never did it before and every time it would happen it would blip the cel for a split second. Sometimes it would do it and sometimes it wouldn't. Datalogging wouldn't pick up the cel when i checked the logs and if i left the car running and checked for codes with the jumper it would show none. So at that point i was thinking man i must have fried something in my ecu again...but whats strange is since then i've tuned 3 other cars this weekend and it didn't do it on any of them.
I'm thinking maybe somehow something got corrupted in my .bin when I tuned for my new turbo the day before it happened. It never did it before that. I'm running a motorolla 2.5bar and using crome 1.1.14 if that helps. So do you guys think this sounds like an ecu issue or something else?
Matt
Old Jul 31, 2006 | 03:41 PM
b18ccivics's Avatar
Default Re: Weird CEL and fuel cut (SOHC_MShue)
you sure you are not loosing 12v, it a bump you ignition cuts off for a second, just an idea.
Old Aug 1, 2006 | 09:33 AM
SOHC_MShue's Avatar
Default Re: Weird CEL and fuel cut (b18ccivics)
i'm thinking it may have had something to do with the map sensor connections. i taped them up a little better today to keep the seperate pins from coming close to eachother and i think its better now. Hasn't done it to me since.
Battle Monkey
K Series
Oct 31, 2016 06:13 PM
kyang03
Mar 6, 2014 07:31 PM
georgiajdm
Feb 17, 2007 12:05 PM
Vtec92Civic
Mar 30, 2005 11:54 AM
is3oo
Oct 14, 2004 07:02 PM
