Some new D16 numbers
Old Jul 31, 2006 | 11:30 AM
ELSpool's Avatar
Default Some new D16 numbers
Hit the rollers again in 110 degree weather, I'm not sure how much this plays a roll, but the numbers were a little shy of the 400whp I was looking for.
Anyways, cars runs strong, happy with the results!
Thanks again to Chris Tapp of Tappauto.com for the great tune.
Setup:
D16Y8
Benson Sleeved
CP/Eagles
Supertech Valvetrain
Stock Y8 Cam
GE IM/GSR TB
EL Manifold
FR T3/T61
Hondata
etc. etc.
Mustang Dyno - Pro Racing Fuels Mark 4 Gas
Old Jul 31, 2006 | 12:52 PM
delspool's Avatar
Default Re: Some new D16 numbers (ELSpool)
nice numbers
Old Jul 31, 2006 | 12:54 PM
igo4bmx's Avatar
damn
Old Jul 31, 2006 | 01:02 PM
eh3 93's Avatar
Default Re: (igo4bmx)
How much boost?
Old Jul 31, 2006 | 02:16 PM
RyanEJ8's Avatar
Nice numbers Sam.
How much boost?
Old Jul 31, 2006 | 02:25 PM
SOHC_MShue's Avatar
Default Re: Some new D16 numbers (RyanEJ8)
Great numbers
Old Jul 31, 2006 | 03:09 PM
alexsracing's Avatar
nice , how much boost?
Im thinking of getting the t3/t61 for my z6 as well
right now I have a t3/t4 50 trim at 17 psi to run a 12.6
Old Jul 31, 2006 | 03:19 PM
spoolin turbo s's Avatar
Default Re: (alexsracing)
that torque curve is sweet
if you could rev to 9k rpm's that powerband would absolutely rock
Old Aug 1, 2006 | 04:04 AM
ELSpool's Avatar
finally turned it up to 25 psi, going to race and see if I can hit my 11's
2800lbs 4dr pig
Modified by ELSpool at 1:27 PM 8/1/2006
Old Aug 1, 2006 | 04:06 AM
DfwBB6's Avatar
Default Re: (ELSpool)
Old Aug 1, 2006 | 04:57 AM
1epmugenlude's Avatar
Dam! nice numbers!! I wish my h22 could do that. Get some timeslips now, good luck
Old Aug 1, 2006 | 07:14 AM
gitwidit's Avatar
Default Re: (1epmugenlude)
Hell ya, nice work! GOod luck at the track and let us know how ya do
d16
4 door
Old Aug 1, 2006 | 10:14 AM
ELSpool's Avatar
got a few more traction parts to put on, and then it's track time
Old Aug 1, 2006 | 10:43 AM
eastbay92cx's Avatar
Hey EL, I'm curious, are you using the stock oil pump / pan? I ask because I've read a couple things about the y8's having inadequate oiling, leading to a knock or bearing failure with the #4 rod. Have you tried to address this at all, or is it running fine?
Nice setup btw, good luck with the 11s.
Old Aug 1, 2006 | 10:52 AM
yellowturbo's Avatar
sweet good results as usual Sam !
Old Aug 1, 2006 | 11:08 AM
ELSpool's Avatar
Default Re: (eastbay92cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastbay92cx &raquo;</TD></TR><TR><TD CLASS="quote">Hey EL, I'm curious, are you using the stock oil pump / pan? I ask because I've read a couple things about the y8's having inadequate oiling, leading to a knock or bearing failure with the #4 rod. Have you tried to address this at all, or is it running fine?
Nice setup btw, good luck with the 11s.</TD></TR></TABLE>
oh I addresed it buy using OEM Y8 oil pump, pan, and rev it to 8500rpm all day long, 3 years running...
Old Aug 1, 2006 | 02:18 PM
Civic TSI's Avatar
Maybe it has to do with the temp but I find these numbers very low, especially the torque. What was your Tq number when you dyno it @ 20psi last year ?
Nevertheless, I wish you a lot more low numbers
Modified by Civic TSI at 6:39 PM 8/1/2006
Old Aug 1, 2006 | 02:34 PM
Kelly.'s Avatar
I've quit using this account
good numbers man.
this is on a mustang and they read alittle low.
track times should be a better measurement of power
i went 12.3 with 300 whp, you will see 11s no problems.
mid 11 in a 4dr would be pimpin
keep us updated
Old Aug 1, 2006 | 02:45 PM
ELSpool's Avatar
Ya, tq number always read low on tapps dyno. There are a tonne of cars come off with numbers lower than normal, but traps speeds well above what it should... either way my car is a pig, oh well, something alittle different
Old Aug 1, 2006 | 06:12 PM
Widebody1's Avatar
yeah mustangs read alot lower... we had honda dyno 501 last year and trap 139... there are hondas on here that make 790 and trap 141 so....
I think the "bearing and oiling issue" with the Y engines has somthing to do with using the P2P map an the timing used. They are pretty much hammering the bearings, i dont think its quite an oiling issue.
Old Aug 2, 2006 | 04:51 AM
Civic TSI's Avatar
Default Re: (Kelly.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kelly. &raquo;</TD></TR><TR><TD CLASS="quote">good numbers man.
keep us updated</TD></TR></TABLE>
I know, I've been on that dyno and it didn't read any lower than the other dynos I went. I think I had 220wtq at the time on Tapp dyno. I have 240wtq @ 15psi right now. At 25psi, I would expect nothing less than 300wtq.
Anyway, if you don't run 11's with this, change the driver
v8eatrr
Nov 26, 2012 02:12 PM
pjr710
Jun 9, 2008 06:58 PM
mrchris1979
Jan 12, 2008 03:45 AM
anothaRRR
Apr 29, 2005 04:30 AM
mengo_charged
May 30, 2004 02:23 AM
