Oil Leak on Return Line
Old Jul 27, 2006 | 04:04 PM
Fatty_1775's Avatar
Default Oil Leak on Return Line
Is there any kind of sealant or something that I can use to help stop my oil leak at the end of my oil drain line. I replaced the line and got new clamps too, yet there is still a little leak. Any help would be appreciated. Oil leak never happened first two years I had my turbo installed.
Old Jul 27, 2006 | 05:55 PM
stealthmode62's Avatar
Default Re: Oil Leak on Return Line (Fatty_1775)
If you've already reinstalled it and it still leaks, I would suspect a possible cut or slice on the end of the hose. If you have a couple extra inches I would take it off again, clean everything, and cut a little off each end to make sure you have good ends.
Old Jul 27, 2006 | 06:06 PM
red cx's Avatar
Default Re: Oil Leak on Return Line (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> If you've already reinstalled it and it still leaks, I would suspect a possible cut or slice on the end of the hose. If you have a couple extra inches I would take it off again, clean everything, and cut a little off each end to make sure you have good ends. </TD></TR></TABLE>
oil can squeeze out of the smallest cracks over time.
qazaq
Jul 29, 2009 01:39 PM
teamidscoupe
May 16, 2007 05:02 PM
stockgreencivic
Jun 14, 2005 07:27 AM
RedStarGsr
Dec 29, 2003 06:07 PM
