are these pistons fixable or are they finished
Old Aug 1, 2006 | 08:20 PM
blackdude's Avatar
Default are these pistons fixable or are they finished
so whats the verdict any help is needed thanks
Old Aug 1, 2006 | 08:25 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: are these pistons fixable or are they finished (blackdude)
fucked, i believe, is the term
Old Aug 1, 2006 | 08:30 PM
99B16Si's Avatar
Default Re: are these pistons fixable or are they finished (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">fucked, i believe, is the term</TD></TR></TABLE>
yup, those badboys were on the verge of total meltdown. i wouldnt be surprised if the top ring gave you a hard time coming out of its groove
Old Aug 1, 2006 | 08:40 PM
blackdude's Avatar
Default Re: are these pistons fixable or are they finished (99B16Si)
just as i thought guess go in trash bye bye
Old Aug 1, 2006 | 08:43 PM
tony1's Avatar
lol
Old Aug 1, 2006 | 09:07 PM
B18C Turbo's Avatar
what happened? bad tune?
Old Aug 1, 2006 | 09:19 PM
blackdude's Avatar
Default Re: (B18C Turbo)
dont know not mine there a friends
Old Aug 2, 2006 | 12:56 AM
torqueless's Avatar
Default Re: (blackdude)
I KNOW WHERE YOU LIVE
Old Aug 2, 2006 | 04:54 AM
USDM 4G VTEC's Avatar
clean them on solvent, make sure you get all the **** out
take it to a machine shop and have them look at them
they are more likely still ok as long as the ring lands arent damaged and the top of the pistons are ok
the skirts can be polished out and the scars can be smoothen out
that was caused by piston slap.... those pistons didnt seem to be on a block with the right bore
Old Aug 2, 2006 | 06:18 AM
99B16Si's Avatar
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">clean them on solvent, make sure you get all the **** out
that was caused by piston slap.... those pistons didnt seem to be on a block with the right bore</TD></TR></TABLE>
bad idea/waste of time IMO
Old Aug 2, 2006 | 06:43 AM
earl's Avatar
Default Re: (99B16Si)
They are history.
Old Aug 2, 2006 | 06:44 AM
waste of time? HA
if hes able to spend $500 on a new set of pistons then great, he wouldnt be posting here
if the local machine shop can inspect them for him, once all the carbon built up and **** is clean, then he will know if they are **** or not, they will be able to tell if the pistons are just worn, or if it has any sign of integrity being compromissed
we can only judge what we see on 2 pictures
have someone locally with knowledge make the descision
Old Aug 2, 2006 | 06:45 AM
tony1's Avatar
Default Re: (earl)
Just rub them on the concrete until they're uniform on the skirts, then get some bondo to fill in the low spots. Let that dry for a bit and put a light coat of paint on the skirts, they'll be good to go.
Old Aug 2, 2006 | 06:47 AM
B18C1CYA's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Just rub them on the concrete until they're uniform on the skirts, then get some bondo to fill in the low spots. Let that dry for a bit and put a light coat of paint on the skirts, they'll be good to go.</TD></TR></TABLE>
Tony you know you cant use bondo , it has to be JB weld , and then rub it a second time , lol
Old Aug 2, 2006 | 08:51 AM
turbodohcsi's Avatar
tony, your talkin about copying srp's/je procedure for making pistons..... wouldnt it be illegal to copy them?
Old Aug 2, 2006 | 10:15 AM
quicksilver1689's Avatar
i ♥ snails
hhahaha
Old Aug 2, 2006 | 10:20 AM
beaver's Avatar
Default Re: (quicksilver1689)
LOL!
Old Aug 2, 2006 | 10:25 AM
rudebwoy's Avatar
I would reuse them, as long as the ring lands are still good.
Old Aug 2, 2006 | 11:50 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (rudebwoy)
those would make good paperweights. id never let them even see my motor
Old Aug 2, 2006 | 08:40 PM
blackeg's Avatar
Default Re: (wantboost)
ive been in the same situation before. i was sooo close to reusing, but i didnt.
peace of mind is worth a lot of money to me, more than the 450 for a new set of pistons
Old Aug 3, 2006 | 05:40 AM
miller's Avatar
Default Re: (blackeg)
if your a smoker they will make good ashtrays
Old Aug 3, 2006 | 06:21 AM
hotimportcrx's Avatar
Default Re: (miller)
Those are DEE-Stroyed
Old Aug 3, 2006 | 09:32 PM
boost4life's Avatar
man thats the nicest paper wait ive ever seen
, soo thats srp/je's secret 2 make big power "bondo" owe and jb weld
Old Aug 3, 2006 | 11:11 PM
97turboteg's Avatar
Default Re: (boost4life)
dude, you'd have to be retarded to re use that, i guarantee it wont last more then 10 miles...just get one new piston. if possible. and good luck, but seriously dont bother trying to fix a f(%#$ up piston
HIboost
Jul 12, 2006 09:27 PM
Kusai.Nihonjin.Desu
Honda Motorcycles
19
Jun 21, 2006 05:08 PM
biggdogg
Feb 6, 2006 12:42 AM
Rob Dizzle
Honda Motorcycles
30
Dec 10, 2005 06:32 PM
lanceh
Mar 8, 2004 03:18 PM
