Is it my 3 bar map sensor?
Old Aug 2, 2006 | 06:59 AM
DXK Eg's Avatar
Default Is it my 3 bar map sensor?
I just got my car tuned at 14 lbs a few weeks ago and I went to the track this weekend and I couldn't boost pass 14 lbs. I turned up the boost a little bit and went to lined up and started off the on first gear and when boost hit's it feels like I hit a wall. Then check engine light came on and my car won't go, but if i let go of the gas so boost does hit I was able to drive it down the track with no boost and the check engine light goes off. After that I turned the boost back to 14 lbs and the car run fine. But I was not happy with my time, which was 13 sec. flat at 102 mph. So is this my hondata that's acting up or is my 3 bar map sensor?
Old Aug 2, 2006 | 07:59 AM
done's Avatar
Default Re: Is it my 3 bar map sensor? (DXK Eg)
you hit boost cut
Old Aug 2, 2006 | 08:37 AM
DXK Eg's Avatar
Default Re: Is it my 3 bar map sensor? (Jordo@KAP)
Meaning ?? What can I do to fix it?
Old Aug 2, 2006 | 09:22 AM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXK Eg &raquo;</TD></TR><TR><TD CLASS="quote">Meaning ?? What can I do to fix it?</TD></TR></TABLE>
check in your hondata settings for the "boost cut"
it seems to be to low, or your 3 bar isnt hooked up in hondata
Old Aug 2, 2006 | 10:12 AM
slodel's Avatar
from my understanding boost cut is for saving the motors life??
your motor is tuned to 14 so if you take it over that its not safe??
should of tuned higher
Old Aug 2, 2006 | 11:30 AM
coneheadsracing's Avatar
Default Re: Is it my 3 bar map sensor? (slodel)
Whats your setup and what size injectors are you running. I can't boost past 15, due to my injectors maxing out, least thats what it feels like to me
Old Aug 3, 2006 | 05:38 AM
DXK Eg's Avatar
Default Re: Is it my 3 bar map sensor? (coneheadsracing)
Thanks for the info. I contacted my tuner and it was a boost cut set at 14 lbs. Time to get it retuned at 18 lbs. I'm running on 780 cc injectors.
92redhatch
Aug 11, 2012 12:55 PM
LSej1
Jul 19, 2008 03:51 AM
DXK Eg
Jul 20, 2006 10:30 AM
EJ8 GSR-T
Apr 11, 2006 07:14 AM
MayhemSi
Sep 17, 2003 08:51 AM
