Little intercooler question
Old Apr 30, 2008 | 06:12 PM
integraturbo96's Avatar
Default Little intercooler question
I want to know how much power my intercooler can hold cause I want to raise the boost on my car. Two day at 10psi on my ls and I want more
My intercooler is a bar and plate with 19x7x3 core.
Thx
Old Apr 30, 2008 | 06:45 PM
totsie7944's Avatar
Default Re: Little intercooler question (integraturbo96)
Its not so much how much power your intercooler will 'hold' as it is, whether or not the air will cool enough so your motor doesn't over heat. With that size though you should be able to run like 12-15 psi...but I am just guess. Without knowing more about your motor, how its build, how much power your making, what turbo, we really can't help you
Old Apr 30, 2008 | 07:01 PM
Default Re: Little intercooler question (totsie7944)
100% stock ls
Gt3076r turbo .60-.80
Ramhorn
3"dp+3"cat in a 2.75" skunk2 exhaust
aproximately 240whp(street tune dont have exact number)
I want 270whp
Old Apr 30, 2008 | 07:07 PM
totsie7944's Avatar
O well you can definately make 270 whp man. haha
Old May 1, 2008 | 06:15 AM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">Its not so much how much power your intercooler will 'hold' as it is, whether or not the air will cool enough so your motor doesn't over heat. </TD></TR></TABLE>
IATs have little to do with coolant temps and a lot to do with detonation.
Old May 1, 2008 | 07:35 AM
chimmike's Avatar
Default Re: Little intercooler question (dpetro1)
the thickness of that core helps you a lot, but 7" tall and 19" wide is fairly small.
I'd say that IC would be good for maybe 325-350hp.
To be safe, I'd upgrade to something about 12" tall and 20"+ wide Gives you a good cross section without being too big that it'll induce a massive pressure drop.
FYI, I don't know how many of you honda guys do this, but I always run hot side piping at least .25" smaller than cold side, so that the the larger piping helps create a scavenging effect thru the intercooler.
Old May 1, 2008 | 07:41 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">
x2
Since you're going to need a retune to run more boost anyway, you can have your tuner log your IATs in order to check whether or not the higher boost is safe for your setup.
TravisBiggie
Jun 21, 2012 09:50 PM
92integraVTECgsr
Jul 1, 2008 09:12 PM
19sec beast
Mar 29, 2006 04:41 AM
eg6T
Jan 10, 2005 10:46 PM
