B16A-T help with oil pressure
hey h-t,
hopefully this will be an easy fix if anything is wrong BUT...
my crx has a b16a with turbo in it...it is tuned off s300 by anthony at av-engineering. Anyway, my oil light has come on i believe 3 times, when it does, the car shuts off...dunno why.
im letting the car idle as we speak...oil pressure is a little over 25psi and -17 in vacuum.
ive been driving the car before someone hit me, and it will drive perfectly fine until i slow down enough to where im hardly moving, in neutral...and the oil light will come on and just shut off...now i can just crank it back up and its fine and will drive, but whats the deal?
thx, and im about to drive it again...see if i can possibly make it do the same thing
ill let you know
any suggestions?
ill let you know
any suggestions?
Re: B16A-T help with oil pressure (A BOOSTED CRX)
dumb ? but you do have enough oil in there??
oil pump going out...
oil pickup clogged for some reason..
where is the oil line for the turbo tapped into??
Re: B16A-T help with oil pressure (ShortbusEK)
oil is full and golden
walbro 255 fuel pump...and no its not going out..brand new
not clogged
possibly plugs? it doesnt break up, so i dont think that would be it
just took it for a drive...RUNS PERFECT ...just idle- it will die out sometimes..
WTTTTTTTTTTFFFFFFFFFFFFFFFFFF
not clogged
Supahr_Ed
05-27-2006 11:51 AM
