Which sohc block?
Old Apr 30, 2008 | 09:32 AM
mercutio_07's Avatar
Default Which sohc block?
I working on a build for the summer and I'm trying to figure out which block to get, ZC or z6? I have a built z6 head and will be using 75.5mm 9:1 wiesco's and h-beam eagles. I tried a search to see if this had already been discussed (as I'm sure it has), but nothing with any relevance popped up. I'm shooting for ~400 whp with the rev limiter set around 8500-9000.
Old Apr 30, 2008 | 01:08 PM
Default Re: Which sohc block? (mercutio_07)
up it up
Old Apr 30, 2008 | 01:39 PM
welfarepc's Avatar
pretty high rpm goal for a SOHC...
id go for the z6, cheaper and easier to get,other than that they are basicly the same
unless ur talking about a D15b, but then id still go z6. (and they are still very similar as well)
Old Apr 30, 2008 | 02:16 PM
dr_latino999's Avatar
Default FV-QR
8500 - 9000? What CAM are you planning, whose doing the epic headwork, and what gearing are you using to optimize this?
Old Apr 30, 2008 | 03:11 PM
Default Re: FV-QR (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">8500 - 9000? What CAM are you planning, whose doing the epic headwork, and what gearing are you using to optimize this?</TD></TR></TABLE>
I'm using a 59300, stage 2 p&p z6 head by performance porting, and full supertech valvetrain. I have a soon to be heat treated and rebuilt y8 tranny that i'm trying to find an lsd for.
I've been looking for a z6 block for a good while now with no luck, but I found a ZC block for next to nothing and wanted to know if there are any significant differences or little pain in the *** differences between the two.
Modified by mercutio_07 at 7:31 PM 4/30/2008
Old Apr 30, 2008 | 07:37 PM
mike93eh2's Avatar
i shift at 8500 rpms. whats the big deal? its still making power at 8500 but i just dont want to rev past that for longevity purposes.
and btw get a z6 block. you can find them anywhere.
Old Apr 30, 2008 | 09:55 PM
redex04's Avatar
Default Re: (mike93eh2)
d16z6
Old May 3, 2008 | 09:43 AM
Default Re: (redex04)
So I decided to hold off for the z6, thanks a lot guys.
From reading I know that stock blocks are good for around 400-500whp, if darton replacement sleeves are better than stock, around what whp are they good for?
Old May 3, 2008 | 04:29 PM
^^^sleeves anyone? ^^^
Old May 10, 2008 | 11:42 PM
Rtboy10's Avatar
i would get a z6 oy y8
Old May 13, 2008 | 08:05 AM
Default Re: (Rtboy10)
What is the difference b/n the z6 block and a6 block?
I tried a search, but the search function is still down.
Old May 13, 2008 | 01:29 PM
Default Re: (mercutio_07)
bump for an answer
Old May 13, 2008 | 01:31 PM
mini-me-power's Avatar
a6 has slightly thicker see walls, better for boost I was told
Old May 13, 2008 | 01:39 PM
Default Re: (mini-me-power)
can anyone else tell me if there's a difference b/n the z6 block and a6 block?
Modified by mercutio_07 at 8:54 PM 5/13/2008
Old May 13, 2008 | 05:06 PM
gettin it's Avatar
The a6 block has thicker walls. For sure. Its the same block that full race used when they did there sohc build for pinks.
Old May 13, 2008 | 11:51 PM
qweakers's Avatar
Default Re: (gettin it)
some of the a6, are suppose to have a stronger main cap assembly, other than that the fan switch sensor is on the back of the block, that is all i can think of.
Old May 14, 2008 | 10:59 AM
Default Re: (qweakers)
Thanx for the posts, picked up an a6 block today!!
Casp3r88
26
Jun 25, 2009 07:28 PM
HondaTomcat
Sep 12, 2004 01:35 PM
ZC_Vtec_Civic
Jul 31, 2004 05:54 PM
civi93ex
Sep 5, 2003 10:12 PM
B18AJB16A2
Feb 16, 2003 02:00 PM
