84.5 headgaket issues
Old Apr 22, 2008 | 04:42 PM
1clnef9's Avatar
Default 84.5 headgaket issues
i have been having alot of headgasket issues after going to 84.5mm at high boost (32 pounds with a s372 fully built ls/vtec) it will blow the headgasket every time when i was 84mm never had one headgaket problem i am still using a oem b20 head gasket with arp studs I was curious if you have any sugestions on what head gasket to go with and yes the head and the block have both been inspected any help would be appreciated
Old Apr 22, 2008 | 07:07 PM
rintegration's Avatar
Default Re: 84.5 headgaket issues (1clnef9)
What sleeves are you using and is your block o-ringed ?
Old Apr 23, 2008 | 10:22 AM
a1320addict's Avatar
Default Re: 84.5 headgaket issues (rintegration)
How many times have the headstuds been torqued down? Generally you can get 3 uses out of them, I would check them out...you may possibly have stretched them out.
If you continue having problems, look into the L19 stud kit or go to a 1/2" stud.
Old Apr 23, 2008 | 03:55 PM
bosted coupe's Avatar
the block was sleeved at rs manchine so its not o ringed do they make a 84.5 honda b20 headgasket or 84 is ok
Old Apr 24, 2008 | 12:30 PM
PHDZINE's Avatar
IF your headgasket is smaller than your bore...then your headgasket is hanging inside your combustion chamber. The lip of your headgasket could be heating up and causing pre-ignition. It's ok to go bigger headgasket than your bore but not smaller headgasket than your bore.
Old Apr 24, 2008 | 12:59 PM
cjordan's Avatar
Default Re: 84.5 headgaket issues (PHDZINE)
i have a 84.5mm bore and we recently pulled the head and found were the edge was barely in the cylinder so we upgraded to a 85mm headgasket.
Old Apr 24, 2008 | 01:36 PM
where would u get a 85 mm head gasket does honda sell oversize stuff like that or do i have to get a golden eagle one
Old Apr 24, 2008 | 03:13 PM
CerealKiller's Avatar
Default Re: (bosted coupe)
Golden Eagle gaskets are Honda gaskets. GE just Overbores them to fit Customer Specs. You can also try cometic, but I'd stay with Honda through GE.
Kanagias
16
Sep 27, 2015 04:27 AM
Topdawgg
Apr 9, 2007 09:29 AM
2ndgentegracer
Oct 9, 2006 07:24 PM
crv-techu
Mar 11, 2006 04:05 PM
turboex
Nov 20, 2002 04:40 PM
