My turbo LS project
Old Apr 22, 2008 | 05:22 PM
integraturbo96's Avatar
Default My turbo LS project
This is my project. Will be tuned next week
RLD manifold
Tial 44mm WG
HKS bov
GT3076r .60 .82
Small intercooler (temporary)
Custom IC piping
3" downpipe and cat
Skunk2 70mm exhaust
Stock LS
Let me know what you think
Old Apr 22, 2008 | 05:26 PM
b18 hatch mike's Avatar
Default Re: My turbo LS project (integraturbo96)
i like it looks good get some vids after the tune
Old Apr 22, 2008 | 05:58 PM
legomytego's Avatar
manifold looks great it looks like that ramhorn is much tighter then other companys like its closer to the block cant really tell but good luck what kinda numbers are you looking for ? and please get a dyno graph and post thanks
Old Apr 22, 2008 | 06:09 PM
Default Re: (legomytego)
I don't know how many whp it will do and I will not have dyno sheet cause the tuning will be street tune on .6 bar 8-9lbs.
P.s. sorry for my crappy english I do my best
Old Apr 22, 2008 | 11:26 PM
PhantomX's Avatar
Default Re: (integraturbo96)
Clean set up...... is that the Coolant Line on the right???
Old Apr 23, 2008 | 02:39 AM
legomytego's Avatar
Default Re: (PhantomX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraturbo96 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know how many whp it will do and I will not have dyno sheet cause the tuning will be street tune on .6 bar 8-9lbs.
P.s. sorry for my crappy english I do my best </TD></TR></TABLE>
turn the boost up more then that she will last as long as you have a good tuner that 3076 will really start to wake up are you just going to run of wastgate or something ? what are you tuning with ?
Old Apr 23, 2008 | 03:00 AM
yeah its the coolant line because it's not plugged(set up not 100% finished)
my LS burn oil and I will keep the boost low for the moment.My set up is overkill cause its was for a forged motor but money problem. The tuning will be done with chrome pro(I think)
Old Apr 23, 2008 | 04:38 AM
dcfreak's Avatar
hey like the setup but how hard is it to spool that turbo man. i wanted to do a .48 60-1 and some people said it would be hard for me to build boost.
Old Apr 23, 2008 | 05:21 AM
Schister66's Avatar
Man U FTW
Its a nice setup, but its a little overkill for a stock LS. You're not going to get the benefits of the GT30r on your stock block. You would have made the same power numbers and had comparable spool with something like a T3/T04e 50trim. If you're planning on building the bottom end, then you have a great setup for the future
Old Apr 24, 2008 | 05:33 PM
I have a question guy. My obd0 plug wires for my injectors are inversed. How I suppose to plug them? I have install my resistor box but not the connector cause in not sur the way to plug the wire. My injector are precision. Thanks for your help
175Shot4Door
Feb 3, 2009 04:35 PM
chihuahuamanx
Apr 19, 2005 08:14 AM
j-robsDA
Aug 20, 2004 10:42 PM
sCeRaXn
Feb 6, 2004 07:00 PM
DIRep972
Feb 11, 2002 09:16 PM
