keep jdm foglights on a turob eg
is there any piping or ic kit that have enough clearance so that you can run the piping and still keep your foglights cause i have a setup on there right now that will no way allow me to do that so if anyone can help thanx
Re: (da_dude)
if you get a IC with the inlet's and outlet's are ALL the way at the bottom, it can fit.. it's close, and you MAY have to cut a LITTLE bit off the bottom of the bracket, but it should fit..
car isn't turbo'd yet, but everything was cut and fitted and the piping will fit..
buda18
08-18-2006 12:06 PM
crxsiperf
05-06-2005 10:11 AM
