11:1 to high?
Old Apr 28, 2008 | 01:37 AM
littlejj26's Avatar
Default 11:1 to high?
I have CP pistons 81.5 mm, 11.1 cr and will be on forged rods. So i did a little bit of searching, but couldnt come up with a complete answer. Is that compression ratio too high for daily boost? I have an OEM headgasket as well. My plans for psi on daily will be about 6 psi or so. With power goals at a max of 300-320whp.
I am currently looking for lower compression, but are hard to come buy cuz nobody wants to trade but if it comes down to it, i thought about keeping them. I just need to know if it would be safe or do-able. Thanks in advance for the imput!
Old Apr 28, 2008 | 04:29 AM
chimmike's Avatar
Default Re: 11:1 to high? (littlejj26)
you're going to have a lot of fun battling detonation. You'll really have to bump back timing to stop detonation, and it'll be very sensitive.
It can be done, but it has to be tuned perfectly.....
Old Apr 28, 2008 | 07:25 AM
Schister66's Avatar
Man U FTW
With the right fuel, you should have no problems making your power goal. Dont worry about the PSI needed to get to your goal, measure your goals in terms of whp instead. If you think 11:1 is too high, just look around the FI Forum and you'll find a 400whp stock block S2K. You could make your 300-320whp goal on pump gas and even more if you have access to E85.
Old Apr 28, 2008 | 10:37 AM
littlejj26's Avatar
Ok, thanks a lot guys. My main thing was figuring out about the whole detonation issue. Im doing my best to try and find lower compression pistons, but these came brand new in a deal i got with a b17 block for only $700. But Im going to keep searching and talk to my tuner to see what my options would be.
Old Apr 28, 2008 | 11:19 AM
jewjew bean's Avatar
Default Re: (littlejj26)
it's one thing if you already have the pistons in the block but it would be foolish to go with 11:1 just to save a few buck.
MikhailBjornson
Mar 28, 2017 06:09 PM
99siRACER
Jan 3, 2012 12:20 AM
95civhb
Jan 4, 2010 01:49 PM
SiRay13
May 30, 2006 11:48 AM
xonn
Jul 18, 2003 12:02 PM
