overheating......sometimes
Old Apr 23, 2008 | 08:03 PM
zex_cool's Avatar
Default overheating......sometimes
few days ago i went to tune the new e85 fuel. did 6-7[3rd AND 4th gear] pulls with about 10min between each one and the temp never went over 198*. yesterday i did a quick 3rd gear pull an noticed my ECT were climbing slowly after. it went up as high as 220*. i kept driving and it fell to 200* after a few min [no more then 4,5min]. both days temp was relatively the same at around 50-60*
this is car is my DD for now and the temp never gets over 194-196* driving around and getting on it here and there. only time the overflow tank gets full was few weeks ago when i was at the track and yesterday after that little run.
there is some headgasket looking stuff in the overflow[no oil/coolant mixing anywhere] but im thinking it could be from last year when my old motor blew one.
ideas ?
btw, bone stock b16a; holset he351cw @12psi; maximum of 16.75* of timing.....
Old Apr 24, 2008 | 11:33 AM
zex_cool's Avatar
bump ??
Old Apr 24, 2008 | 05:26 PM
zex_cool's Avatar
lol
Old Apr 25, 2008 | 05:49 AM
maddog20's Avatar
Default Re: (zex_cool)
does it overheat now after you go into boost everytime now?
or do you fill up your overflow everytime after the first incident?
Old Apr 25, 2008 | 08:55 AM
zex_cool's Avatar
Default Re: (maddog20)
nope, no overheating. it did it only those two times. overflow stays normal too.
Old Apr 26, 2008 | 07:14 AM
antTypeR's Avatar
Default Re: overheating......sometimes (zex_cool)
sounds dumb, but check the coolant. could be low if there's a leak somewhere. probably should clean out that reservoir also. do you know if your fan is working?
hondatuner020
Jun 27, 2016 04:31 AM
g0b
Honda Civic (2001 - 2005)
Mar 19, 2013 01:59 AM
sc34dc4
Apr 29, 2010 07:50 AM
djoye
Apr 9, 2008 06:51 PM
187Chor
Nov 27, 2007 05:05 AM
