plz help
Old Apr 27, 2008 | 08:51 AM
95gsrEG's Avatar
Default plz help
i have a 95 civic ex with a ls/vtec turbo with dsm 450 injectors....the car starts but runs very rich and it wants to keep dieing out wen its idling.....then if u try 2 give it gas it completely bogs out and wont rev past 3 grand??any ideas??
Old Apr 27, 2008 | 10:28 AM
Evilparadize's Avatar
Default Re: plz help (95gsrEG)
Management type?
Old Apr 27, 2008 | 11:14 AM
95gsrEG's Avatar
Default Re: plz help (Evilparadize)
its a base map ls/vtec turbo just so i can drive it...
Old Apr 27, 2008 | 12:20 PM
Si Shane's Avatar
Base maps aren't for driving, they are for starting your car so you can tune it. You can't tune a car that isn't on, so you need a basemap. They are not for driving around.
Old Apr 27, 2008 | 12:38 PM
Default Re: plz help (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evilparadize &raquo;</TD></TR><TR><TD CLASS="quote">Management type?</TD></TR></TABLE>
Old May 1, 2008 | 09:24 AM
95gsrEG's Avatar
i got some **** figured out and im gettin hondata.....but the car is revin real slow and has no power???
Old May 1, 2008 | 10:17 AM
chimmike's Avatar
you're "gettin" hondata?
what the hell management do you have now? you said "base map" but what exactly do you mean by that? Do you have ANY management right now?
Are you possibly running stock ecu with NO basemap? This would explain why the car is running hellishly rich at idle and dying, because you have 450cc injectors being run by an ecu programmed for some about half that size.......
I think you need to get a few more things in line before worrying about having power. Like, proper engine management and tune.
Old May 1, 2008 | 04:41 PM
Default Re: plz help (chimmike)
Management type?
Answer the f'inkg question so that we can help you, well at this point, more like flame you!
WOW...
Old May 1, 2008 | 05:52 PM
95gsrEG's Avatar
its on a base map for lsvtec..and if ur guna be [freak]n *** monkey stay the [freak] off my thread..
Old May 1, 2008 | 07:02 PM
Kris's Avatar
Default Re: (95gsrEG)
I think they want to know what's on a basemap .. what is "it"? You just have a chipped ecu?
Don't start it again till you get it tuned on Hondata ......
Old May 1, 2008 | 07:05 PM
Turbogixxer's Avatar
Default Re: (Kris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kris &raquo;</TD></TR><TR><TD CLASS="quote">I think they want to know what's on a basemap .. what is "it"? You just have a chipped ecu?
Don't start it again till you get it tuned on Hondata ...... </TD></TR></TABLE>
You spelled the EMS wrong, it is Neptune
Old May 1, 2008 | 07:37 PM
Kris's Avatar
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
You spelled the EMS wrong, it is Neptune </TD></TR></TABLE>
Haha ORLY?
Old May 1, 2008 | 07:53 PM
FastEg6's Avatar
Yeah, we need to know what EMS you're running in order to help you out, a Basemap really doens't tell us much. Are you running a stock p28 ecu that isn't chipped or, one that is chipped...or whichever....Tell us what you're using so we can help you.
Old May 1, 2008 | 10:06 PM
Default Re: (FastEg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrEG &raquo;</TD></TR><TR><TD CLASS="quote">its on a base map for lsvtec..and if ur guna be [freak]n *** monkey stay the [freak] off my thread..</TD></TR></TABLE>
At this point, I'm in awe! The tremendous amount of knowledge you incur within you is amazing. The common sense that you lack to answer a f'ing simple question is unbelievable. Why ask for help when you neglect to answer a question that is essential, in order for H-T, to attempt to help you out? This train wreck of thread should be locked and vanished from H-T to never bee seem by even the novice. You want me to stay out…I will, but with that attitude and lack of common sense, I think the rest of H-T will do the same. Good luck in the future pal, you're going to need it. By the way, even an “*** monkey” would comprehend further than you can, in your entire life span.
Old May 2, 2008 | 04:51 AM
chimmike's Avatar
Default Re: (Evilparadize)
my guess: It's not a basemap. He's blowing smoke because he has no idea wtf he's talkin bout.
I think he's on the stock ecu trying to run those big ole injectors without any adjustment.
Old May 2, 2008 | 08:13 AM
95gsrEG's Avatar
its a base map for lsvtec with 450 injectors
Old May 2, 2008 | 09:05 AM
vtecb18c's Avatar
How do you know your running a basemap when you don't know the specs???? did you or anyone else ever touch your ems? are you running ems or your factory ecu with a chip thats burned for ls/v? you gotta give us some info if you want us to help.
p.s- and start by telling us what your "basemap" is please.
Old May 2, 2008 | 10:20 AM
chimmike's Avatar
Default Re: (vtecb18c)
this kid doesn't know wth he's talking about.
basemap tuned for 450cc injectors? doubtful. running rich and dying at idle? Sounds like an overfueled stock ecu to me.
Old May 2, 2008 | 11:05 AM
blwn95civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrEG &raquo;</TD></TR><TR><TD CLASS="quote">its a base map for lsvtec with 450 injectors</TD></TR></TABLE>
ok this might help us out if u can answer this question... WHERE DID U GET THE BASEMAP?
Old May 2, 2008 | 11:49 AM
95gsrEG's Avatar
phearable.net...i told them that it was a b18b with a b16 head...dsm450 injectors...and a 60trim.....the reason it was dieing was there was a wiring problem....it idles fine now but it has no response....and revs extremly slow
Old May 2, 2008 | 12:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">Base maps aren't for driving, they are for starting your car so you can tune it. You can't tune a car that isn't on, so you need a basemap. They are not for driving around.</TD></TR></TABLE>
Old May 2, 2008 | 01:17 PM
vtecb18c's Avatar
i give up
Old May 2, 2008 | 04:37 PM
95gsrEG's Avatar
it runs the same with my friends ecu that has been tuned by hybrid for an ls with 450s...it runs good till it warms up then it loses all its power?
Old May 2, 2008 | 05:31 PM
chimmike's Avatar
sounds like a sensor issue now. coolant temp sensor maybe.
Old May 3, 2008 | 09:18 PM
civicjoe's Avatar
Default Re: (chimmike)
any cel? if so pull the codes and post em up
