turbo exchange?
Old May 1, 2008 | 07:39 PM
gmctruck68's Avatar
Default turbo exchange?
i just bought a turbo manifold, i have a vemon intake, will a turbo off of a 3sgte mr2 engine work?
Old May 2, 2008 | 06:32 AM
builthatch's Avatar
MiG-21 superfan
Default Re: turbo exchange? (gmctruck68)
uhh...
what manifold is it...
Old May 2, 2008 | 06:54 AM
chimmike's Avatar
Default Re: turbo exchange? (builthatch)
I'm gonna take a stab at it and say no.
what do you want that tiny little itty bitty turbo for anyways?
Old May 2, 2008 | 02:12 PM
gmctruck68's Avatar
i got it on ebay, please dont laugh.
• T3/T4 STAINLESS TURBO MANIFOLD
• Custom-made Equal Length Tubular Stainless Steel Turbo Manifold
• BRAND NEW DESIGN NEW RELEASE
• 100% GUARANTEE AGAINST CRACKING / DEFECTS
• NO BOOST CREEP - NEW WASTEGATE DESIGNED FLANGE
• EXTRA WELDS OUTSIDE AND INSIDE THE PORTS
• PORTED AND POLISHED / PORTS AND PRIMARIES
• 304 STAINLESS CONSTRUCTED
• Fits any D SERIES MOTOR
• This manifold was custom-made.
• This manifold is for Hybrid T3/T4 OR any T3 Flanged Turbo - 35 or 38 MM Wastegate Flange
• The manifold is made out of SUS304 Hi-Grade Stainless to help disperse heat. This manifold is drag-race quality, and similarly design manifolds can be found on professional drag cars.
• And since this manifold is tubular steel, it flows better than cheap cast iron and is less prone to cracking.
Old May 2, 2008 | 02:14 PM
gmctruck68's Avatar
Default Re: turbo exchange? (chimmike)
im not very knowlebable when it comes to turbo's, but my friends that see the turbo on my mr2 engine say, damn, thats a big turbo, what do you consider to be a small turbo?
all i know is that its bigger than the one's that come on eclipses, T3/T4 right?
Old May 2, 2008 | 02:51 PM
chimmike's Avatar
that stock 3sgte is not ANYWHERE near as big as that t3/t4.
also, that manifold will crack. And that toyota turbo won't bolt on that manifold.
Old May 2, 2008 | 07:51 PM
gmctruck68's Avatar
how do you know the manifold will crack? if i stay under 8 psi will it still hold up?
Old May 3, 2008 | 04:59 AM
chimmike's Avatar
it's a cheap ebay manifold. apparently you haven't looked at the FAQ section yet.
I suggest you do.
Old May 3, 2008 | 07:05 PM
gmctruck68's Avatar
would it help if i got the manifold heat treated?
Old May 3, 2008 | 10:07 PM
Miatamania's Avatar
doubtful.
Most ebay stuff uses thinner walled steel...**** just cracks.
It is neat to watch flames shoot out when it does it on the dyno though...wouldn't exactly recommend that though.
Old May 4, 2008 | 11:21 AM
hondamn1320's Avatar
Default Re: turbo exchange? (Miatamania)
just because it's an "Ebay" manifold it will crack? i've seen plenty of "ebay" manifolds hold strong for years, and some crack within months. there are Pros and Cons to everything.
Old May 4, 2008 | 12:33 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gmctruck68 &raquo;</TD></TR><TR><TD CLASS="quote">would it help if i got the manifold heat treated?</TD></TR></TABLE>
You really should probably do some research, no offense but you jumped in the water way to quick. No heat treating will not work.
slammedef06
Jun 25, 2005 08:34 AM
1.8EG-T
Nov 16, 2003 02:22 PM
