Looking to Turbo my D16y7...first time booster...
Howdy gents! I own a 2000 hatch with a Y7 engine. I'm well versed in mechanics and I know how everything works (I'm a 63B (wheeled vehicle mechanic) in the military). I want someone to point me in the right direction for turbo'ing this vehicle.
I know that I want an intercooler and that I want an ecu for tuning. I also want to run stock internals on the motor and I will be getting an aftermarket clutch/flywheel.
Any help pointing me out in the right direction and this could turn into a build thread. Thanks for your time.
Re: Looking to Turbo my D16y7...first time booster... (GTlvr82)
at the top of the FI section there is a sticky "FAQ"
read everything in that section and than come back here with any questions.
truly you shouldn't have many after that
another good link is the official sohc-t
https://honda-tech.com/zerothread?id=1643764
Re: Looking to Turbo my D16y7...first time booster... (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie »</TD></TR><TR><TD CLASS="quote">at the top of the FI section there is a sticky "FAQ"
Thanks...I can't believe I forgot about the stickies...they have one in the EG+ forum and its sweet!
Ok now I have a few more solid questions.
-Due to the fact that the cat is located in the exhaust manifold is relocating the O2 sensors going to be a big deal? I am going to have some kind of tuning equipment so I'm sure it can be negated.
-What turbo is best suited for the D for mild/moderate boost. I would prefer the boost to kick in fairly low in the rpms and stay up fairly long.
-Is aftermarket or DSM injectors necessary for 5 to 6psi on my engine?
https://honda-tech.com/zerothread/1067168
http://www.turbobygarrett.com/....html
https://honda-tech.com/zerothread?id=1263795
https://honda-tech.com/zerothread/2152865
https://honda-tech.com/zerothread?id=979788
https://honda-tech.com/zerothread?id=1023414
https://honda-tech.com/zerothread?id=1004578
https://honda-tech.com/zero...02591
just a few that i thought would be helpful
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 »</TD></TR><TR><TD CLASS="quote">Ok now I have a few more solid questions.
not a problem. you will be doing a obd1 conversion with a p28 ecu and with the tuning software you will be able to edit any of that info that you might need to edit
there are many different opinions on what is "best for sohc" i was building my kit on a t28 base
https://honda-tech.com/zerothread?id=2279805
ya ya it sucks sad story... thanks in advance
there are two options on injectors
saturated and peak/hold
factory are saturated so it's easier to replace them with the same
that way there is no need for a resistor box
keep a eye on my stolen car post because my kit will be up for sale more than likely </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 »</TD></TR><TR><TD CLASS="quote">Thank you both very much...sent you a PM jeremie.</TD></TR></TABLE>
back at ya
back at ya
Benjithx
07-06-2006 08:35 PM
jDMJeRk
05-20-2004 05:36 PM
