Where can I find 5/8" Turbo Oil Drain line?
Re: Where can I find 5/8" Turbo Oil Drain line? (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI »</TD></TR><TR><TD CLASS="quote">Please let me know asap... I have -10 and its to small.</TD></TR></TABLE>
5/8" is the same as -10.
Re: Where can I find 5/8" Turbo Oil Drain line? (B R Fittings)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B R Fittings »</TD></TR><TR><TD CLASS="quote">
5/8" is the same as -10.</TD></TR></TABLE>
It's a tad bit smaller trust me.
10 an is the same as 5/8.
5 / 8= .63 inch
10 / 16= .63 inch
if you are talking about the flaring of the end, the -AN fittings are a JIC fitting in hydraulic terms. if you try to use a 5/8 NPT or flare fitting from menards or homedepot, it won't work. you have to go to catco or pirtek to get a JIC fitting.
Modified by batboyvaj at 1:43 PM 4/25/2008
5 / 8= .63 inch
10 / 16= .63 inch
civicguy
04-14-2003 09:59 AM
