Car is cutting out. HELP!
Old Apr 26, 2008 | 03:45 PM
WhiteVX's Avatar
Default Car is cutting out? HELP!
The short story. I have a 92 vx with a 95 gsr motor/ trans. 60-17 turbo, stock ecu, 310 injectors, 6 lbs boost. nos fuel pump, str fuel rail. When the car gets warmed up, in any gear, running at a 1/4 throttle or more. The fuel on my air/fuel gauge cuts completely out as the car falls on its face. And i press all the way to 1/2-3/4 throttle before it surges back. any ideas, Thanks
Modified by WhiteVX at 5:57 AM 4/28/2008
Old Apr 26, 2008 | 03:50 PM
LA_HONDAS's Avatar
Default Re: Car is cutting out. HELP! (WhiteVX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteVX &raquo;</TD></TR><TR><TD CLASS="quote">The short story. I have a 92 vx with a 95 gsr motor/ trans. 60-17 turbo, stock ecu, 310 injectors, 6 lbs boost. nos fuel pump, str fuel rail. When the car gets warmed up, in any gear, running at a 1/4 throttle or more. The fuel on my air/fuel gauge cuts completely out as the car falls on its face. And i press all the way to 1/2-3/4 throttle before it surges back. any ideas, Thanks</TD></TR></TABLE>
that's why
get your ecu chipped for 310 injectors and go it tuned
and them injectors are to small for a turbo car get some 550's or bigger
Old Apr 26, 2008 | 05:59 PM
WhiteVX's Avatar
i would say yes, but i've been running this set up for years. and this problem has just occured recently.
Old Apr 27, 2008 | 06:17 PM
WhiteVX's Avatar
help
Old Apr 29, 2008 | 05:31 PM
WhiteVX's Avatar
ttt
Old Apr 29, 2008 | 05:55 PM
blwn95civic's Avatar
was the car ever tuned? if not then i dont see how you were driving it without a tune, thats just asking for problems
Old Apr 29, 2008 | 06:29 PM
WhiteVX's Avatar
Default Re: Car is cutting out. HELP! (blwn95civic)
it has a vafc. it was tuned on the street, by my turbo guy. not on a dyno. it ran like a champ for 3-4 years. i am fixing to upgrade to a s300,with bigger injectors, but i would like to figure out my problem instead of covering up or creating more problems.
Old Apr 30, 2008 | 07:16 PM
WhiteVX's Avatar
help
Old Apr 30, 2008 | 09:01 PM
FastEg6's Avatar
Sounds like you're not getting enough fuel, get it chipped at least.
Old May 17, 2008 | 04:42 PM
SpeedDreamz.com's Avatar
Default Re: (FastEg6)
IF you are near Tuscaloosa run it by my shop and I can check it out for ya.
Mobile Electronics
Tuscaloosa
554-1554
ask for Tracy
B18c1vicrx
Aug 29, 2007 08:47 PM
onefstek
Dec 5, 2005 10:29 PM
hotinteggy
Oct 15, 2004 07:10 AM
GForceInteg
Jul 15, 2003 05:40 PM
unFOB4U
14
Sep 10, 2001 06:31 AM
