Heating problem with boosted LS vtec need help
Old Apr 27, 2008 | 09:50 PM
Poey2's Avatar
Default Heating problem with boosted LS vtec need help
Hi HT
I just got my boosted LS vtec running and its having a heating problem. It doesnt overheat right away but after some time it would heat up. It would heat up when I come to a stop after driving around even without boosting. I have to stop and let the car cool down.
I have new Mishimoto half radiator with slim fan in a EG. I am thinking the radiator is not able to cool the motor. Also I put in a new thermostat when the motor was assembled.
What do you guys think is the problem?
Thanks in advance.
Paul
Old Apr 28, 2008 | 08:22 AM
bpwrdeg's Avatar
Default Re: Heating problem with boosted LS vtec need help (Poey2)
I am having a similar problem with my B16T, what plugs are you running, if you didn't buy a cooler plug that could be the problem.
Old Apr 28, 2008 | 09:25 AM
dpetro1's Avatar
Default Re: Heating problem with boosted LS vtec need help (bpwrdeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpwrdeg &raquo;</TD></TR><TR><TD CLASS="quote">I am having a similar problem with my B16T, what plugs are you running, if you didn't buy a cooler plug that could be the problem. </TD></TR></TABLE>
spark plug heat range has pretty much nothing to do with coolant temp.
OP, more detials please. is the thermostat opening? does the fan work properly? did you bleed the system?
Old Apr 28, 2008 | 09:31 AM
Poey2's Avatar
Default Re: Heating problem with boosted LS vtec need help (dpetro1)
spark plugs are BKR7E and Im pretty sure the thermostat opens because i can drive around for some time before it heats up. I wired the fan to the ignition so it will be on all the time and the fan is blowing the right direction.
After driving for like say 20 min under boost, the temperature would go up when I stop at light.
I am thinking of getting a Koyo radiator or go with bigger fan or change both.
Anymore ideas?
Old Apr 28, 2008 | 09:32 AM
Poey2's Avatar
Is there a way to bleed the system? How?
Old Apr 28, 2008 | 10:11 AM
dpetro1's Avatar
if temp is going up only when at lights i would look into the fan. the rad isnt getting enough airflow when stopped.
617ej1
May 4, 2010 04:44 PM
xxthabest1xx
Nov 14, 2006 07:47 PM
the_illest_soldier
Jun 5, 2006 11:35 PM
xXx Justin xXx
21
Mar 19, 2004 05:26 PM
DEVIN22CBR
Apr 9, 2003 12:27 PM
