Urban Indians Civic Coupe 2.0 GSR - 750whp build
Urban Indians Civic Coupe 2.0 GSR - 750whp build * Made 703whp @ 35PSI*
OK since its been awhile since I have posted I will update the World as to what I have been doing, going for 750whp on c16 400-450 on pump chevron 94
<FONT SIZE="4">Basic Rundown of my Car</FONT>
1994 Honda Civic Coupe SI
Purple
CF Hood
16" Rota C8's w/ Falken Azenis
KSport Adj Coilovers
Skunk2 Camber Kit
Peakboost Turbo Kit ( will take manifold and cut flange off to fit T4 housing) ***POLISHED GT35R w/ fittings, & 2 sets of coolant lines for sale***
- Down in abby getting a rollcage at Passenger Performance Diesel ( passenger is a part of the shop miller) Miller Performance BMW
- Motor is assembled and awaiting delivery at Laskey racing
- Time car will be back on road. End of may
things purchased recently
- Hondata 4 bar map sensor
- ARP Pressure Plate Bolts
- Dual Walboro intake pump set-up w/ 20' -8 AN line
- 13" Matte Black VPD rims w/ M&H 24.5x8.5x13
- Hondata Intake Manifold Gasket
- Victor X Edelbrock Manifold - painted wrinkle paint black
- Tony1 style BR Fittings catchcan w/ black AN fittings
- Tilton Hydro Control Valve
- New LS 5th gear
- moroso door bar kit
- AEM fuel pressure regulator
- Black russel fuel filter
- Racer Stev(Honda-tech sponsor) heat treated gears
- NRG suspension kit
- Prothane Motor Mount inserts
- 67mm Holset HX52 ( similar in size to a GT4094/S366) Turbo is off a newer Volvo Semi
Stuff waiting to ship from Laskey
Bronze BDL Fuel Rail
Bronze BDL Cam Seals
Bronze BDL Cam Gears
ATI Harmonic Balancer street version
Half Sized PWR Rad
ARP Everything( ie. Headstuds)
Stage 3.9 axels from driveshaft shop
Block & Stage 3 head, assembled. (fully built engine with new timing belt, tensioner and bolt, arp head studs and head gasket.)
List of things awaiting overnight parts delivery from JDM Land
Twin Disk CC clutch
Carbon Fibre Trunk
Skunk2 Pro1 Cams
Skunk2 Front Strut tower bar
Precision 1600CC injectors
Magnetic drain plugs(tranny & oilpan)
Blox rear 21mm sway bar
Skunk2 Lug Nuts
Wilwood 4 corner ITR replacement disk brakes
FJO injector driver & wiring kit
Pics of the Volvo
Modified by Urban_Indian at 11:05 AM 4/24/2008
Modified by Urban_Indian at 8:13 PM 7/27/2008
Purple
CF Hood
Skunk2 Camber Kit
- New LS 5th gear
Half Sized PWR Rad
Twin Disk CC clutch
Carbon Fibre Trunk
Skunk2 Pro1 Cams
Skunk2 Lug Nuts
Pics of the Volvo
Re: Urban Indians Civic Coupe 2.0 GSR - 750whp build (Wopsicle69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wopsicle69 »</TD></TR><TR><TD CLASS="quote">where did you get a turbo like that from and how much?? </TD></TR></TABLE>
I got it from a friend for $500 new. There was a guy on ebay selling them for $825 shipped
Re: (661rex89si)
anyways here is the update
3" custom intercooler piping
Custom backdoor 12" garrett core intercooler
custom topmount twin scroll dual 38mm tial WG Manifold
4" food grade stainless exhaust
custom roll cage w/ door bars
i bought a video camera so i'll take some video this weekend
pics
HX52 V. GT35R
pics
HX52 V. GT35R
Re: (Urban_Indian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Urban_Indian »</TD></TR><TR><TD CLASS="quote">
lol, did somebody actually advertise it as that or try to sell you on that?
Re: Urban Indians Civic Coupe 2.0 GSR - 750whp build (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
lol, did somebody actually advertise it as that or try to sell you on that?</TD></TR></TABLE>
The difference between regular 316 stainless and foodgrade stainless is the quality I will let someone else with more knowledge explain that, I had it explained but its all greek to me.
I'll let my fabricator swing his knowledge ***** around here
Re: Urban Indians Civic Coupe 2.0 GSR - 750whp build (Urban_Indian)
Have him come swing his *****. lol
"foodgrade" is not a grade of stainless. There are quite a few different grades, but that's not one of them. Regardless, cheepo 304 is more than sufficient for downpipes and exhaust. You don't plan to park the car in the ocean for prolonged periods of time, right?
Re: Urban Indians Civic Coupe 2.0 GSR - 750whp build (kyden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyden »</TD></TR><TR><TD CLASS="quote">my downpipe is welded with medical grade stainless, lol. </TD></TR></TABLE>
chronic?
more pics!!!! set up looks bitchin. and turbo is humongous.
chronic?
Re: Urban Indians Civic Coupe 2.0 GSR - 750whp build (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Have him come swing his *****. lol
"foodgrade" is not a grade of stainless. There are quite a few different grades, but that's not one of them. Regardless, cheepo 304 is more than sufficient for downpipes and exhaust. You don't plan to park the car in the ocean for prolonged periods of time, right? </TD></TR></TABLE>
Wrong.
Food grade (sanitary stainless) stainless steel is completely different than the standard mill grade tubing and cold formed u bends. Its like comparing DOM to ERW.
Some notables, like DOM, sanitary ss has a mandrel run through the inside and outside to create a consistant wall thickness. The tubing is also polished on the I.D. and O.D.
304,316,321 etc are the metalurgical grades, it doesn't necessarily have anything to do with the quality of the manufacturing process, chinas version of 304 is not the same as americas version of 304.
The following requirements must be met and printed on sanitary tubing:
ASME SA249 (specification for burst pressures etc)
ASTM a270 (specification for seamless & welded austenitic stainless steel sanitary tubing)
UNS #
Tube construction (welded or seamless)
Manufacturer
HT#
Building #
Date manufactured
Shift #
Fittings (elbows, couplers etc) go through the same process. There is no comparison.
Wrong.
UNS #
Manufacturer
HT#
Building #
Date manufactured
Shift #
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Gotcha, heard of sanitary stainless tubing, never heard it called food grade. </TD></TR></TABLE>
Yeah the names get thrown around, kind of like how everyone one call aftercoolers intercoolers.
Re: (ls1_datsun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls1_datsun »</TD></TR><TR><TD CLASS="quote">Looks good!
Thats not a garrett core though, or atleast doesn't look like any i've seen..</TD></TR></TABLE>
Its some core from Mopac. Unsure what brand it is.
still trying to find an exhaust flange for this holset....
