rc injector help.
Old Apr 23, 2008 | 05:17 PM
postman's Avatar
Default rc injector help.
searched but no one ever gives a good answer. to the question. if someone has a pic of them installed correctly that would be awsome
when installing the injectors with supplied lower grommet. the injector and grommet sit on top the intake instead of sinking into the bores. is this correct. fuel doesnt leak anywhere but im worried about a vacumme leak.
Old Apr 23, 2008 | 06:53 PM
rmcdaniels's Avatar
Default Re: rc injector help. (postman)
Which intake manifold and head?
Edit - Hopefully not a new AEBS manifold on a GSR head.
Old Apr 24, 2008 | 05:59 AM
dpetro1's Avatar
they are installed correctly. i spoke to RC about this with my 550cc injectors. I actually have a copy of the install instructions on my computer at home that state the injectors should sit on top of the grommets.
Old Apr 24, 2008 | 06:55 AM
totsie7944's Avatar
Default Re: rc injector help. (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">they are installed correctly. i spoke to RC about this with my 550cc injectors. I actually have a copy of the install instructions on my computer at home that state the injectors should sit on top of the grommets.</TD></TR></TABLE>
? I think he is saying that he doesn't have the grommets down in the runner holes on the manifold and just has them chilling at the top, which is wrong.
OP, you need to post pictures so we have a better understanding of what you are talking about.
For example if you look at a Edelbrock manifold, the runners will have a large hole the exact size of the suppled RC grommets, and then a smaller hole below that which the injector sprayers shoot into. You install the grommets into the manifold and then the injectors go into the grommets. It is dam near impossible to get them in sometimes because it is so tight.
You might need to try some liquid soap or something that will slick the surfaces upa little bit.
Old Apr 24, 2008 | 06:58 AM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">
when installing the injectors with supplied lower grommet. the injector and grommet sit on top the intake instead of sinking into the bores. </TD></TR></TABLE>
he has them installed correctly
Old Apr 24, 2008 | 07:31 AM
totsie7944's Avatar
That is wrong...it doesn't sit on top of the bore, the lower grommets sink into the bore in the runner...maybe we are interpreting him different. That's why I said he should post pictures up.
Old Apr 24, 2008 | 07:56 AM
dpetro1's Avatar
Default Re: rc injector help. (totsie7944)
he is saying the grommet in in the IM but the injectors them self are sitting on top of the grommets, this is how they are suppose to be installed.
ill let the OP clear it up but im sure he is fine
Old Apr 24, 2008 | 09:25 AM
totsie7944's Avatar
yea thats right...sorry. Just checked on RC's sight and they do just sit on top to create that seal...
Old Apr 24, 2008 | 01:20 PM
postman's Avatar
still dont get this. messing with it tonight and if i dont think i got it ill post pics. you dont leave the old one in do you and have the new lower grommet sit on top the old one do you. any body with a link to inst..
Old Apr 24, 2008 | 01:32 PM
dpetro1's Avatar
you only need the rc lower grommets. i think you have then installed just fine. here's a link the the instructions http://tiger.towson.edu/~dpetro1/rc550.doc
Old Apr 24, 2008 | 02:11 PM
postman's Avatar
thanks for the link. i got them in right.
h22bb1
Oct 21, 2008 08:42 PM
B18CRacer
Jul 22, 2004 11:07 AM
magic hat #9
Apr 22, 2004 08:19 PM
killa_lude
Oct 30, 2003 04:13 PM
SIK IN DA HED
Apr 10, 2002 01:04 AM
