help with an h series drag turbo kit
i have a drag turbo kit, but the wastegate connects to the manifold, and then what about the other pipe coming from the wastegate? it just ends, where is that pipe supposed to go or what am i missing? thanks in advance.
Re: help with an h series drag turbo kit (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">it should be dumpiong down to the ground
its normal</TD></TR></TABLE>
oh if that is normal because the pipe coming from the wastegate is only about a foot long and then it just ends. let me double check because wouldn't there be exhaust coming from it?
Make mine whatever you want
Re: help with an h series drag turbo kit (SilverPanda)
Yes sir, that is your wastegate dump. Leave it as it is. The point is to get those exhaust gasses away from the turbo.
05-02-2011 10:20 PM
JSpecwest
08-06-2001 07:01 PM
