spark plugs you would recommend for my setup?
i am in the process of putting a drag turbo kit on my 2001 honda prelude. i was just wondering which spark plugs you would recommend for me to install on my car. i know i need some with a colder spark, also what kind of oil should i use? royal purple? thanks in advance.
Re: spark plugs you would recommend for my setup? (SilverPanda)
i would order ngk 1095's make sure you set the gap a little tighter then stock for most applcations i usually run .030 but the more boost the tighter you want it... good luck!
