is 400whp obtainable on 15 psi?
setup is as follows:
ls/vtec
81mm wiseco 8:1
eagle rods
stock head w/itr valvespring
t4/60-1 84a/r hotside 70a/r coldside p-trim
tubular mani
38mm wastegate
3'' intercooler piping
tuned on crome pro
im trying to figure out iof thats good for 400 whp on 15 psi. i see alot of similar setups with smaller turbos make close to that goal on lower boost. the motor will be reving to 9k. thank you for your input.
ls/vtec
81mm wiseco 8:1
eagle rods
tubular mani
38mm wastegate
tuned on crome pro
Re: is 400whp obtainable on 15 psi? (turbo-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-crx »</TD></TR><TR><TD CLASS="quote">setup is as follows:
ls/vtec
81mm wiseco 8:1
eagle rods
tubular mani
38mm wastegate
tuned on crome pro
im trying to figure out iof thats good for 400 whp on 15 psi. i see alot of similar setups with smaller turbos make close to that goal on lower boost. the motor will be reving to 9k. thank you for your input. </TD></TR></TABLE>
Why does it matter if its at 15psi?
If you make that power at 13psi, or 22psi, its still 400whp regardless...
Psi is just a number, should be almost irrelevant in your goals.
Does it change anything if someone says yes or no?
ls/vtec
81mm wiseco 8:1
eagle rods
tubular mani
38mm wastegate
tuned on crome pro
well because thats what wastegate spring i have. i wana see if i can do it on just the wastegate spring because i dont have a boost controller.
Re: is 400whp obtainable on 15 psi? (97CWITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97CWITR »</TD></TR><TR><TD CLASS="quote">
Does it change anything if someone says yes or no? </TD></TR></TABLE>
Agreed, why are you so concerned with 15psi?
The answer to your question though is yes, but most likely not with that setup.
I made 380hp @ 14psi with a LOG manifold, and 2.5'' DP. My plan this summer is to switch to a EL manifold (ramhorn) and 3'' DP. I know for a fact this will put me over 400 @ 14psi. The reason I got this number is because I have higher compression (9.8:1) and 01 ITR cams, which really helped. Regardless I wouldn't be too concerned with your PSI level. Just take it to a good tuner and let him work his magic, whatever PSI level he is comfortable with will be the PSI you need to run your motor @.
Go to the dyno and let us know how it does. We don't allow e-dyno or guess the power threads.
PSI does not equal power. There are a lot of things that come into play.
Man U FTW
Re: (turbo-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-crx »</TD></TR><TR><TD CLASS="quote">well because thats what wastegate spring i have. i wana see if i can do it on just the wastegate spring because i dont have a boost controller.</TD></TR></TABLE>
We wont know what you'll make at 15psi, but boost controllers are cheap...pick one up if you're really concerned with making 400whp.
dd69ma
09-25-2006 11:59 AM
Topdawgg
02-17-2006 10:20 PM
Freeltec
01-16-2006 11:31 PM
