smoke
Old Jan 10, 2006 | 12:46 PM
kabrante's Avatar
Default smoke
i just installed a turbo and now i noticed that the car is throwing smoke from the breather filter on the valve cover. I remove the oil cap and alot of smoke is coming out.
is this normal?
Old Jan 10, 2006 | 01:17 PM
TypRice's Avatar
no.
might be a rings.
Old Jan 10, 2006 | 01:19 PM
rkrone's Avatar
Default Re: smoke (kabrante)
no, sounds like you are burning oil possibly??
not really sure but that doesn't sound normal, tell us more about your set up
did you add a little more oil for the turbo/oil lines?
Old Jan 10, 2006 | 01:49 PM
JDMHatch95si's Avatar
Default Re: smoke (rkrone)
Sounds like you shouldve bought yourself a catch can , your have a fried ring/rings
Old Jan 11, 2006 | 09:48 AM
kabrante's Avatar
piston 1 has 95 comp
all others 185
damn piston ringlands
Old Jan 12, 2006 | 08:32 AM
integra racr04's Avatar
yeah , well ur first cylinder is shot, the stock comp. shoud read 200, 95 is waaaaaaaaay low, id get that looked ASAP
Old Jan 14, 2006 | 10:15 AM
Default Re: smoke (integra racr04)
i have a 94 turbo del sol and that same thing happened to me
tore it apart and the ringlands were blown, they are cast from the factory and very weak under boost situations. honda's also have a terrible pcv system for boost so you need to upgrade to a oil catch can....but i'd be willing to put money on that you blew your ringlands out
roll8221
Feb 5, 2015 05:30 AM
zimmy709
May 18, 2012 03:16 PM
myessay
Jan 27, 2012 01:59 AM
EuroMan
Feb 2, 2006 05:34 PM
blackdelsolsi
Jul 31, 2003 12:12 AM
