da with b20
Old Jan 9, 2006 | 07:57 PM
integturbo's Avatar
Default da with b20
i juss installed a b20 (stock) in a DA and it wont start. i used the ls tranny, distributor, wiring harn, and intake manifold. it got spark, fuel pressure, and it cranks! but it juss wont start. is there any mods needs to be done that i forgot to do?
Old Jan 9, 2006 | 09:15 PM
AnDThEnWuT's Avatar
Default Re: da with b20 (integturbo)
did you remember to hook the chasiss ground back up the the tranny? just an idea.
Old Jan 9, 2006 | 09:25 PM
integturbo's Avatar
Default Re: da with b20 (AnDThEnWuT)
yes i did.everthing is hooked up. i juss wonder if there's anymore mods or anything else that i should swap from the ls engine.
Old Jan 9, 2006 | 09:41 PM
TheCheeseWedge's Avatar
check your timing
check your fuses
Old Jan 9, 2006 | 09:42 PM
Spectrum24x's Avatar
Default Re: da with b20 (TheCheeseWedge)
simple thing, but maybe bad starter?
Old Jan 9, 2006 | 10:32 PM
scheistermeister's Avatar
^^ if starter was bad it wouldnt crank
Old Jan 9, 2006 | 10:48 PM
XstouterX's Avatar
Default Re: (scheistermeister)
thats not entirely true the starter would crank a little...but it sounds as if ur timing is all goofed up...check all ignition componets, distributor, rotor, cap, ignitor, ignition switch
Old Jan 10, 2006 | 03:05 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: (XstouterX)
ignition wires
gsr_sleeper916
Dec 31, 2010 04:59 PM
IGuess
Nov 1, 2009 07:41 PM
lookout22
Jun 22, 2009 07:53 PM
El-Joka
Jul 25, 2006 01:46 AM
R6E6I6D
May 2, 2005 08:19 PM
